which clutch with my red and aquamist setup?
I havent done the research to know if that slave has more travel than the quarter master. But both clutches use the small 7.25 clutch cover. Those clutches require very little finger travel to get that cover to disengage. My guess is the tilton TOb wont do a thing. The spec clutch is 8.5 diameter and the fingers need more travel than the 7.25. My idea was to increase the master cylinder bore diameter. This would certainly reduce the pedal travel needed to get the cover disengaged. This would give the syncros several micro seconds more time to do their job.
That's what were doing with the slightly larger Tilton master cylinder. In reality all I'm looking to do is disengage the clutch about 0.2 of a second quicker. The larger master SHOULD make that possible.
From: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
Not that proven. They material is too thick and you have to break in a clutch several thousand miles according to drifto or whatever his name is. Read up on RYU's evo on how he has problems. Spec blames this on the evo's master cylinder. Supposively the clutch works great after you break it in for several thousand miles.
Ryu has lockout issues on high rpm shifts. You'll find that Ted B loves his clutch however. While you are breaking in the clutch for several thousand miles, you are abusing your transmission because the clutch is not fully disengaging.
https://www.evolutionm.net/forums/ev...p-tuned-2.html
https://www.evolutionm.net/forums/ev...c-install.html
Ryu has lockout issues on high rpm shifts. You'll find that Ted B loves his clutch however. While you are breaking in the clutch for several thousand miles, you are abusing your transmission because the clutch is not fully disengaging.https://www.evolutionm.net/forums/ev...p-tuned-2.html
what about the spec singles? the 2+ and the 3+ look interesting with 499 and 595 torque capacity? I curious of the increase in pedal pressure some would not be bad as I have no interest in a loud chatting clutch or a rough engaging puck design. Ive had act2600 on my dsm and it was okay but a bit on the heavy side but after all the bad act reviews on the evo I want to go another direction but the twins seem like overkill.
scheides
Nov 1, 2010 08:58 AM
fred 62
15
Nov 15, 2007 04:56 AM
1000cc, 85, adjustment, aquamist, clutch, custom, disengaging, e30, evo, extremev, fully, injectors, m3, quartermaster, setup
