Mixed messages
Old May 1, 2012 | 04:14 PM
AWDs's Avatar
Mixed messages
So I've been having mixed messages about my injector size. I'm running an aquamist hfs-3 meth kit with 50/50 mix, and I called a tuner and he said I have to upgrade my injectors to atleast 1000cc injectors before he will tune it. Then others say I shouldn't have to because of the meth. He also said I would make no where even close to 400 which is what I'm shooting for.
My mods are
Bbk full turbo
Gsc s1 cams
Ets licp
3" turbo back (catless)
Walbro 255lph
Map 02 dump
Hallman mbc
Aquamist hfs3
Act 2600
Old May 1, 2012 | 07:47 PM
evo8426's Avatar
Your tuner is obviously an idiot if he says you will not make 400. I make 400 on stock turbo no problem. But that was on the standard Dynojet. If you are running stock injectors then you do need to upgrade them.
Old May 1, 2012 | 07:49 PM
n2oiroc's Avatar
if you are going to buy injectors, i wouldnt bother with anything smaller than 1,000's anyways.
Old May 1, 2012 | 09:31 PM
AWDs's Avatar
Ok thanks I just bought some precision 750s I don't think the bbk full is made for over 500 hp anyway correct?
Old May 2, 2012 | 01:19 AM
Acree's Avatar
Hah, why would you go small when even the most massive injectors these days can drive and idle like stock?
-Acree
Old May 2, 2012 | 01:26 AM
Blue91lx's Avatar
What he said. Oh, and you can make 400 without meth (which is what you should do, especially if 400 is your goal).
Old May 2, 2012 | 10:54 AM
AWDs's Avatar
-Acree
I understand where your coming from but huge injectors aren't what I need for my particular setup.
Old May 2, 2012 | 10:56 AM
AWDs's Avatar
Thanks I'll shoot for that, but if I can add 50 or so more with meth, I won't mind.
Old May 2, 2012 | 11:00 AM
gsrboi80's Avatar
My mods are
Bbk full turbo
Gsc s1 cams
Ets licp
Walbro 255lph
Map 02 dump
Hallman mbc
Aquamist hfs3
Act 2600
Do yourself a favor and stay far away from that tuner you called. 750s will be fine on pump with meth . If you look to E85 down the road though obviously you'll need bigger
seven10
Jun 4, 2016 05:16 PM
Noe18
Dec 3, 2013 04:31 AM
chriswolf81
Nov 29, 2013 06:53 PM
EvilTechnology
Feb 28, 2013 05:29 AM
Knguyen228
Jun 5, 2011 06:05 PM
