DIY Transmission Re-Build Tips
Old Jun 9, 2013 | 12:13 AM
  #136
elhalisf's Avatar
Originally Posted by 06EvoIXmr07
Anybody have the part numbers for the 6 speed input shaft bearings and snap rings??
MN132400 for the bearing.
the snap ring comes in many thicknesses so you have to know which snap ring you need before you order.
Old Jun 10, 2013 | 08:48 AM
  #137
Eno-Evo's Avatar
Any one have the part numbers for the evo 9 3rd gear and counter ?
Old Jun 10, 2013 | 10:14 PM
  #138
Dave W.'s Avatar
EVO 9 3rd gear, input shaft; MD748305
EVO 9 3rd gear, output shaft; 2528A047
Old Jun 19, 2013 | 02:48 PM
  #139
kazx9r's Avatar
nothing
Old Aug 29, 2013 | 06:36 PM
  #140
My03evo's Avatar
I'm currently starting to assembly my evo 8 5 speed trans, is there any tips or tricks to pull the races back out of the cases? Mine is a slight press fit so it obviously doesn't come right out. Any kind of homemade tools anybody made to pull the races out? I'm assuming it would have a 90 degree bend and fit in the two little slots to wedge it out. Any tips or tricks to get the races out?
Old Aug 29, 2013 | 07:48 PM
  #141
wizzo 8's Avatar
Old thread but a good one
Old Sep 8, 2013 | 11:26 AM
  #142
My03evo's Avatar
Any tips or tricks to get the bearing races out of the case?
Old Sep 8, 2013 | 12:35 PM
  #143
evobros's Avatar
Subscribe
Old Sep 8, 2013 | 09:31 PM
  #144
Dave W.'s Avatar
Put the case on a hot plate. Pry up evenly so the race comes out straight.
Old Sep 15, 2013 | 04:53 PM
  #145
My03evo's Avatar
Any tips on prying it out? (Ill try and find a hot plate in the meantime) There's not much room to get under the lip and pry on the race? What tools do you use?
Thanks
Old Sep 15, 2013 | 05:01 PM
  #146
flabber's Avatar
Flip the case over an bang the ish out of it on the floor , well thats what i did
Old Sep 16, 2013 | 12:09 PM
  #147
My03evo's Avatar
Anyone else?
Old Sep 16, 2013 | 12:33 PM
  #148
slipperychicken's Avatar
Good heat gun could substitute for the hot plate.
Old Sep 16, 2013 | 12:40 PM
  #149
kazx9r's Avatar
They are not pressed in except the bell-housing diff one, did you read the rebuild manual?, they use a special tool MD999566 to get them out but they are still just slide in. But its just a claw tool. you can make one on a bench grinder and then attach it to your slide hammer.
The mainshaft bell housing side is usually the hardest one to pop out. If you get them stuck, just tap them back down again until they are even and pry them out one side at a time or if your hands are small you can probably pry both sides at the same time but you'll probably cut your hands on the sharp casing edges. Also I'm assuming you've probably created some burr's on the casing, so you will have to knock the cup in and then de-burr the mushroomed edge so the next time the cup won't get stuck on it.
Take a small propane torch and heat the edges if needed but I've opened 6 transmission and only needed heat for the diff bell housing side because that is a press in.
By the way the one upgrade I didn't read is to change the tcase bolts from 8mm to 10mm.
Old Sep 16, 2013 | 12:56 PM
  #150
anthonypazsd's Avatar
Are the Outer Races that sit In the Transmission Housing suppose to Spin Freely?? My thought is that the Races are suppose to sit firmly in place while the Input/Output Shaft Bearings spin on on the Races themselves. Upon disassembling the tranny, the races spun freely with the turn of my fingers.
