DIY Transmission Re-Build Tips
Old Feb 1, 2011 | 12:38 PM
  #106
PAdutch's Avatar
Cant watch the vid at work. Ill save it for when I get home.
Old Feb 1, 2011 | 02:47 PM
  #107
Walt's Avatar
Very informative thread, thanks guys!! Will use it when i do my clutch and a evo 8 4th gear upgrade.. Subscribed!!!
Old Sep 14, 2012 | 12:03 PM
  #108
Wheatley's Avatar
Sorry to bump such an old thread but there are several people in here I'd like opinions from. I heard a noise from my transmission and decided to pull it. The car has a 4.11 fd, 26" hoosiers and trapped 149 so I know its going to be hard on parts but I'm thinking my problem can be solved with a tapered roller bearing on the input shaft.
The primary damage was 2 ears on the friction ring in the #3 synchro had broken off. We noticed on this fairly fresh transmission that the 3-4 fork had excessive wear as well. We think removing the end play from the input shaft and preloading it with a tapered roller bearing (like what jacks is offereing) will solve this issue of excessive movement of the input shaft that the standard roller bearing is allowing. I know that bearing is an issue even in stock evos but a high tq car (my car makes 620ft lbs) with a qm and a lot of drivetrain stress is only going to amplify that issue.
Any opinions and does anyone have a lead on where to purchase one other than jacks? I don't know if he is selling them as a set separately of a full transmission rebuild.
Old Oct 5, 2012 | 09:40 AM
  #109
real fast's Avatar
Can't you just get the input shaft bearings from mitsuparts.com or your dealer. I'm pretty sure the input shaft bearings are revised now a days well that's what I read a few pages back. I'm also redoing my trans as we speak and this tread has a lot of good info
**edit I see what your talking about Wheatley..The stock bearings on the input shafts are roller and you want to put a tappered one's? What input shaft bearings are you running before you took the trans apart?
Old Oct 5, 2012 | 10:41 AM
  #110
ILuvJDM's Avatar
quick question: my fresh rebuilt tranny and TC drive amazing, but would Torque Solution motor mounts make a whine in 1st and 2nd noticeable in the cabin? I can hear the whine in those 2 gears almost like a straight cut gear in a race car... is that normal?
Evo IX SE with Evo 8 3/4 gears and Wavetrac LSD
Old Oct 5, 2012 | 03:14 PM
  #111
elhalisf's Avatar
I have had more failures of the input shaft bearing in the last 1.5 years than previous years. I cant remember exactly how many transmissions i have rebuilt, but i have had 4 of them fail. None of them fully broke, but they started making knocking noise.
I have actually been more reluctant to replace them these days.
Old Nov 9, 2012 | 06:05 PM
  #112
elhalisf's Avatar
Found a set of tapered roller bearings that do work. Timken part numbers 26118, 26283, 28138 and 28315.
Just put them on the input shaft and they fit perfectly.
Used a shim that got me 0.10mm of preload.
I would suggest that the next size up snap rings from the dealer.
MD746709 1.51mm spline side of the shaft
MD746603 1.51mm drivers side of the shaft
Old Nov 16, 2012 | 06:43 PM
  #113
elhalisf's Avatar
Edited the post above. found a set that did work this time.
Old Nov 16, 2012 | 10:13 PM
  #114
teribble's Avatar
Great info. Did you get it back together and hows it feel? I need to open up my transmission but haven't had the ***** to tackle that job.
Old Nov 16, 2012 | 11:47 PM
  #115
Wheatley's Avatar
Thanks for the info!
Old Nov 22, 2012 | 01:34 AM
  #116
chad99evo's Avatar
where to find the double roll pins? size?
Old Nov 22, 2012 | 01:38 AM
  #117
chad99evo's Avatar
would like to see some field tests of these bearings. like what i see. got it running/tested yet??
Old Nov 25, 2012 | 10:36 AM
  #118
elhalisf's Avatar
Put in 500 miles on the transmission yesterday, with 400 highway miles and 50 miles on the inde motorsports ranch track. Used a 3/4 tank of gas in that 50 miles, so it was a lot of hard driving, and lots of shifting.
First impressions;
  • Gear box is overall nosier, especially first
  • Slightly harder to shift into gear from a stop, especially when cold
  • the up-shifts definitely feel crisper
  • Didn't feel any change with the down-shifts
Fluid used is redline MT-90, so that could have an effect on the harsher cold shifting. Haven't done is fast/high rpm 1st/2nd shifts, but i will test that later.
In the next couple of days, i am going to drain out the transmission fluid, and look for any metal shavings. That will give me an idea on the bearing wear.
Old Nov 25, 2012 | 11:06 AM
  #119
Dave W.'s Avatar
Double roll pins are stock in the 6 speed trans.
Is that a brass bearing retainer on the large input shaft bearing? Could it be weaker? Maybe look for yellow/brass in the oil when you drain it.
From my experience the input shaft should have a tiny amount of freeplay, or a very tiny amount of preload, otherwise it's hard to put into first gear from a stop. Hopefully it'll loosen up a little as the miles roll by. Thanks for the update!
Old Nov 25, 2012 | 11:56 AM
  #120
elhalisf's Avatar
instead of using double rolled pins, i have used smaller pins to insert inside the oem shifter pin. 28mm long, 3mm diameter.
part number 91611A171 from mcmaster-carr is where i am ordered them from.
