ACT, you suck
Old Jul 12, 2009 | 09:27 AM
  #91
cij911's Avatar
This is quite strange...I had lock out a few times on my stock clutch, but have never had it on my ACT HDSS setup (stock flywheel ) ....Unfortunately I believe there is a problem with your setup - maybe caused during installation and maybe a result of the flywheel you chose....
Who have you spoken to at ACT ? I have received great customer support from them....Sorry you are having issues...
Old Jul 12, 2009 | 09:28 AM
  #92
DBallz's Avatar
From: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
Oh yeah stock flywheel too with no restrictor and stainless line
Old Jul 12, 2009 | 12:20 PM
  #93
Teal2nnr's Avatar
For the record i have a ACT clutch installed in my car by TTP (bought the car out of Atlanta...then ship er up to Canada) and it works fine. As was stated, it's usually best to stick with the same brand of parts ACT clutch, ACT flywheel, that way you don't run into these problems.
Old Jul 12, 2009 | 12:25 PM
  #94
bbyevo8u's Avatar
where is the restrictor pill? in the clutch line?
Old Jul 12, 2009 | 01:55 PM
  #95
Smike's Avatar
Yes.
Old Jul 12, 2009 | 02:12 PM
  #96
gsrboi80's Avatar
HDSS and GruppeS Flywheel
Old Jul 12, 2009 | 02:26 PM
  #97
forcepower22's Avatar
high rpm lockout in EVERY gear here.... saving up for a twin..... clutch needs to go shoot itself in the face.... worst clutch EVER
Old Jul 12, 2009 | 02:34 PM
  #98
LI Pinky's Avatar
Im surprised ACT hasn't hopped on this thread yet?! hmmmmm
Old Jul 12, 2009 | 02:58 PM
  #99
Kracka's Avatar
ACT (ACTman) knows this is a problem and has admitted it in other threads.
Old Jul 12, 2009 | 03:03 PM
  #100
GTijoejoe's Avatar
Originally Posted by cij911
Again, there are hundreds if not thousands of evos that use the ACT clutch w/o problems....It's either an installation problem, driver problem, or power has exceeded clutch specifications....Not really too hard to understand...
You don't think it could be a part issue???????? perhaps part quality
Not saying that it is and I'm not saying it isn't......I know of many SPEC clutch plates to blow up on vw's....and than many that don't.
Old Jul 12, 2009 | 03:05 PM
  #101
RevMoto's Avatar
they won't if you have read every other ACT hate thread. First thing they do and the last thing any consumer should do is blame the customer. The blame it on a bad install. Plenty of people have eliminated that factor and guess what it still exists. Also a small portion of people use fidanza clutch's due to the price. Even with stock, ACT and gruppe-s flywheel their has still been lock-out. Every factor besides the clutch is to blame. A new part is blamed every time. I have owned two ACT 6 puck clutch's on two separate cars. First car the car was taken to Billet racing for the install (they install clutch's all day in evo's). The next was installed by myself and a friend who was a mitsubishi tech. I say it is safe to eliminate the bad install factor. I chose the HDG6 because it was said to be less likely to lock-out than any other act clutch, WRONG! Granted a gruppe-s flywheel was used with each clutch. Will I blame the flywheel like other vendors? NO!
Old Jul 12, 2009 | 04:07 PM
  #102
TTP Engineering's Avatar
We are running 11.40 @ 123 , 93 octane on the ACT HDTTP and have run 10.9@130mph on the XTSS on another setup with methanol.
Old Jul 12, 2009 | 04:20 PM
  #103
Kracka's Avatar
What is the ACT HDTTP?
Old Jul 12, 2009 | 04:45 PM
  #104
ODUB's Avatar
i can only go from personal experience here. i got 70k miles out of my stock clutch and after hearing the problems with ACT, my choice was clear: Exedy Stage 1. BIGGEST MISTAKE OF MY LIFE!!!! i got locked out of 2nd and 4th at anything over 7000rpm. it was terrible. i hated that clutch. i only got 50k miles out of it, and i abused the stocker a lot more than that one. I switched to the ACT HDSS and streetlight flywheel and it feels like stock. no isses at all. i can run it all the way up to the fuel cut and shift, no issues. it's been a great clutch for me. i personally blame my flywheel for the exedy issues. i used a resurfaced stocker. it was probably warped or something. when i put in the HDSS, i changed the flywheel to just to make sure, and haven't had any issues since.
Old Jul 12, 2009 | 04:47 PM
  #105
Clutchdc5's Avatar
weird, ive had a act HDSS and it held up fine, my friend has a ACT 6 puck right now and has to granny shift 4th or else it wont go in
