FP3065, Boost leak Issues.....
Old Jul 26, 2009 | 01:11 PM
partyboy1122's Avatar
I am running an FP3065 and all of a sudden the car won't boost leak test anything over 2psi.
Things I have checked for:
Compression test perfect across the board.
Leak down test was OK. No cylinder had more then 3% leakage.
Eliminated the turbo and placed the tester off the TB and still won't go past 2psi.
Tried using a different boost gauge. Same. 2psi only.
Weird thing is, while doing the boost leak test we put a plastic bag around the exhaust tip, taped it and the bag blew up like a balloon.
Note the car was at TDC, meaning all valves should be shut but for some reason air is leaking through.
This is becoming frustrating not knowing this weird issue.
Any input would be appreciated.
Old Jul 26, 2009 | 03:55 PM
recompile's Avatar
You should pull off the cam cover and timing cover and double check the timing belt to make sure everything is still in time and it hasn't slipped a tooth on one of the gears.
Also, I don't know exactly how the Evo EGR system is setup, but I would think it's possible for the intake <--> exhaust path for EGR could be leaking.
Old Jul 26, 2009 | 05:16 PM
smack_evo's Avatar
umm, i thought tdc only referred to cyl. 1(or one cyl. at a time). there isn't any position that will allow all valves to be shut at once. you may be able to get either the intake or exhaust to shut(not even sure about that) but not everything across the head at once. also you have to account for any overlap on the cams as at tdc they may not both actually be completely shut yet depending on the cams.
Old Jul 26, 2009 | 07:23 PM
CO_VR4's Avatar
The main boost leak test is done through the intake system to the TB. If the TB is closed, you should be able to hear a boost leak of the size you're describing. If you use a air bubble pumped to 35 PSI or so, you will eliminate the compressor noise and can hear perfectly. Do you have a good pressure tester?
Old Jul 26, 2009 | 07:41 PM
Yes I have used this same pressure tester on my car in the past, with this turbo and on numerous other evos. We are pumping 100psi into the system. As Recompile mentioned, I am going to use an EGR block off plate tomorrow, perhaps it's stuck open or sticking.
Old Jul 26, 2009 | 07:43 PM
Import Junky's Avatar
100psi????? Why?
Old Jul 26, 2009 | 08:09 PM
GST Motorsports's Avatar
EGR vac line is off the solenoid.
Below the throttle body, on the side of the intake manifold.
Somebody had the same issue recently and I mentioned the EGR in that thread as well and it was his issue too.
I see it a lot.
https://www.evolutionm.net/forums/7232279-post35.html
Old Jul 26, 2009 | 08:14 PM
Honto's Avatar
Same thing happened to my car ^^^^^^
Old Jul 26, 2009 | 08:15 PM
Old Jul 26, 2009 | 08:39 PM
bboypuertoroc's Avatar
Veteran: Army
I see it a lot.
This.
Tony (was the other person)
Old Jul 26, 2009 | 09:22 PM
dank420's Avatar
A simple line will let that much pressure out? i find that hard to believe.. even tho it may be true
Old Jul 26, 2009 | 09:23 PM
I see it a lot.
Will double check tomorrow and report back here!
Old Jul 26, 2009 | 11:43 PM
No, I single vac line won't, but a line that keeps a EGR closed under pressure that came off will allow an open EGR to let that much pressure out.
Old Jul 28, 2009 | 02:11 PM
What do you know.....vac line to solenoid was off. Thanks GSTM
Spool up feels better, will be boost leaking it tomorrow.
tscompusa
Jun 20, 2016 11:55 AM
AKW89
Jun 9, 2013 04:32 PM
taylorgang
Oct 26, 2011 04:53 PM
partyboy1122
Oct 22, 2011 05:01 PM
hkfeet
Jul 9, 2005 08:37 AM
