More broken parts for the Bad Bish
Kracka, not really. It was hard enough for me to grasp and understand, explaining would just make me look like an idiot. There's more to grinding a cam though than a simple lobe.
Sorry if this has been covered or is obvious, but has anyone looked into the cam sensor problem? I saw somewhere that it is related to cars with AEM computers?
Is it actually the sensor failing, or just the ecu losing sync? What's the fix, a new cam sensor? Has anyone looked into building a cam trigger setup? What's the trigger pattern on the cam sensor? Is it a simple 1 per cycle?
There is a different crank trigger, it's a 12 tooth. I was asked earlier in the thread if I was running the 12 tooth still, as I had it in the car for quite some time. My answer was "no" I had just removed it. Then I got to thinking, there aren't a ton of guys using the 12 tooth but I don't know of a cam sensor problem from anyone using one.
BTW, Hi Tony.
BTW, Hi Tony.
Hi
The reason I ask is because we have similar problems with the Hondas with the EMS and we have a cam trigger kit that replaces the mag sensors in the dist with a hall sensor and solves those problems. The problem is usually that the EMS loses the cam signal at some point and then fires out of time, and you clearly know the results of that. haha
Anyways, if it's worth looking into, we could build something to solve the problem. My guess is it's an AEM problem and not a cam sensor problem.
Or we could put a Motec in it and be done with it.
Brad Brooks I believe was behind the 12 tooth trigger wheel for the EVO and it works quite well. There is quite a bit of set up needed to change over in the actual programming. Much of it, as I was going through it, seemed to be wrong on the base settings for the stock trigger. I think if someone smarter than myself or if AEM would acknowledge the problem, it could be fixed just in the base cal. file. The 12 tooth eliminates misfires, long cranking to start the engine and generally just runs better.
I have the new Haltech on my desk, Motec is way out of my budget. I will probably install the new Haltech and give it a shot. Car runs better now than ever but that last cam sensor has me gun shy of it happening again.
The Motec is cheaper than the engines the AEM has cost you, just something to think about. haha
Sounds like it's just an AEM issue. The 300z's have all kinds of bull**** problems with the cam sensor and the AEM too, you have to change the trigger disk on the Z sometimes with the AEM. Flip a coin. Nice...
Hopefully the Haltech works out better for you.
You are right about the Motec being cheaper than the failed parts! haha
I'm hoping with the complaints I've given and the new AEM being released shortly the issues are going to get looked at. Right now the car is running SO good I'd like to run it again on the AEM, I have to get that 8 second pass out of it. I just don't think I want to risk another problem, so the Haltech seems like a great solution. We will see I guess.
8's on slicks, then 8's on street tires, which ECU is anyone's guess at this point!
Most ecu's needs to know where TDC occurs for ignition.
Most modern imports use some type of a missing tooth wheel now. The EVO 10 for example is one of those.
You meant your friend was a victim of AmateurEngineManagement. How many 'Another Engine Mishaps did he have!
Now if the engine lost it's cam signal the ecu wouldn't know which coil to fire and it should stop firing all together if it doesn't know which cyl to fire! Most Ecu's do this..
Other ecu's only need to see the cam signal once during cranking and will know the correct tdc of the engine while it's running so if you ever lost the cam signal it wouldn't matter as long as you didn't shut off the engine..
AEM though is different story.. LOL..
Hence the nickname "Another Exploded Motor"...
You knows it's funny because that term came from the creators. I remeber way back when the 'gold' box was supposedly disguised in their ecu case but that's another story.
Anyway I'm done cluttering your thread now.
Let me ask you, how would the Haltech handle a situation like the fuel pump resistor relay issue on the Evo X's?
By the way.. glad to hear you point out the cam sensor is used for ignition events which I thought as well but didn't know for sure.
I agree with Tony 110%. Dave, you should seriously look into what tony has done for the cam sensor setup on the Honda's. It's a very nice setup.
Tony I think if you make it... AEM users will buy it.
I did find out this morning that I am/was mistaken. The Haltech does not have knock control. This is a pretty big bummer for me to be honest, not sure where I got that it did have it but now that I know it doesn't I am very up in the air about using it. It's on it's way here now and I'll have it this morning. I'm going to have to do some thinking about it all at this point.
