overheating
Old Sep 8, 2009 | 04:26 PM
pensport's Avatar
overheating
I have a new 57mm pwr radiator, mishimoto racing thermostat, but car temp gets past half (stock temp guage) when its sitting idling or driving slow. My electric fan does go on as its connected to the fan controller and i dont think there is air in the system as i removed the radiator cap and let idle saw no air bubbles. Can anyone help??? Only thing I can think of is I bought a cheap 12" slim line fan off ebay (like $30) which the stats looked good. Do you think I need a higher quality fan? Thanks in advance!
Old Sep 8, 2009 | 04:33 PM
Smike's Avatar
Failed waterpump or headgasket will also result in overheating.
Old Sep 8, 2009 | 04:36 PM
pensport's Avatar
head gasket is brand new, just built a 2.3 stroker... the water pump was only a few months old so didnt replace it before the build.
Old Sep 8, 2009 | 04:51 PM
Resi's Avatar
try squeezing the lower radiator hose with the radiator cap off. When I had removed/reinstalled my Rad., I had the same issue and this solved it. May take a bit of time, but your forearms will get buff!
Old Sep 8, 2009 | 05:37 PM
Evo8Emperor's Avatar
your slim fan kicks on but does your front oem fan kick on which is the important one. Make sure that one is kicking on.
Old Sep 8, 2009 | 05:41 PM
gsrIXevo's Avatar
if the fan kicks on and you see the temp go down... then its working. It may not move as much air as a spal 1630 CFM... but a working fan is a working fan. how long has it been since the install of the radiator?... you may just have air in the system.... most ppl dont squeez the top hoses while the fill up the radiator.
hope some of this ramble helps you out....
Old Sep 8, 2009 | 06:37 PM
pensport's Avatar
im gonna try squeezing lower radiator hose, and check to see if fan on ac condensor kicks on... thanks for some advice... I may order a spal too
Old Sep 8, 2009 | 06:43 PM
bambooi's Avatar
Squeeze all the hoses and make sure the radiator is full.
Old Sep 8, 2009 | 07:28 PM
pensport's Avatar
i let it sit and idle for good 15 minutes or so. temp gauge reached just under 3/4 and fan didnt kick on this time. i checked the fan and it works. I have the fan connected to fan controller but didnt kick on.The fan on the ac condensor didnt kick on either. it did yesterday. soooo fustrating! Maybe i need to hard wire the fans so they are constantly on. I also squeezed the hoses to try get rid of any air
Old Sep 9, 2009 | 03:09 AM
MR. EVO MR's Avatar
dude
my mishimoto thermostat was brand new when it failed on her maiden first drive.
it never opened or it never opened all the way causing my engine to overheat BIG TIME (blown head), I have wax all over the place.
I think everyone should boil water check every thermostat before they install it.
remove and run her without the thermostat and see if she still overheats, this will pin point stuff out.
GL
Old Sep 9, 2009 | 12:18 PM
pensport's Avatar
thanks i will check the thermostat!
Old Sep 9, 2009 | 12:27 PM
roger smith's Avatar
I think it's not cycling your coolant.
Usually the fan comes on when the coolant cycles through the engine + radiator.
I'm not sure what controls cycling of coolant, the thermostat?
Spythere
Jul 5, 2016 03:09 AM
MrHouse
Jun 25, 2014 02:32 PM
88888
Jun 13, 2013 08:40 PM
D1no
Aug 31, 2010 08:36 PM
SmurfZilla
Aug 10, 2009 04:36 AM
