How much power will my setup make [Mega Merge]
Old Feb 10, 2011 | 08:12 PM
  #556
tscompusa2's Avatar
Originally Posted by Rough_draft
How much with my mild setup
Evo viii
Turbo xs fmic
Turbo xs uicp & loco
Turbo xs turbo back deleted cat
Walbro 255
K&n cone filter with maf adapter
Stock turbo
Still debating on cams prolly his 272 or gsc s1
Looking for hopefully around 320 ish
youll hit 320 very easily.. probably 360~ on 93oct.
if you have stock BOV you better change it.
Old Feb 10, 2011 | 08:29 PM
  #557
Rough_draft's Avatar
Forgot that I have a ix bov but what cams will be better?
Old Feb 10, 2011 | 08:33 PM
  #558
tscompusa2's Avatar
the GSC will give more gains over the HKS. The HKS will meet your goal easy tho.
Old Feb 11, 2011 | 08:55 AM
  #559
Mellon Racing's Avatar
Originally Posted by RockmanX
1.5 hours away for you to fill up some barrels for e85. hmmm thats some true dedication to the sport right there. LOL they opened a station in front of the mall for me so like 10-15 minutes away for me. anything over 45mins im not bothering. I can see why you love you some pump gas numbers. same here
nice, wish it were closer to me. I run 93 99.9% of the time for that reason.
Evo viii
Turbo xs fmic
Walbro 255
Stock turbo
350+ should attainable with cams especially, I would go with the S1 (stock springs) or S2 if you don't mind upgrading to the beehive springs.
Old Feb 21, 2011 | 07:19 PM
  #560
2006blkevo9's Avatar
How much power, 1/4 mile times?
Evo IX 19000 miles
stock clutch
3119lb with me in it
FP black ported/ 25psi wastegate
Kelford 272/272 cams (stock springs)
STM upper intercooler pipe
Ebay FMIC
Injen lower intercooler pipe
Tial non-rec blow off valve
STM 3" intake (Speed Density)
Megan Racing Tubular header
Titek 02 housing
3" downpipe w/cat delete
HKS carbon Ti catback exhaust
Precision 780cc injectors
Agency power Fuel rail
STM fuel pressure regulator
Walbro 255 pump
Spoolin up COP
Stance GTr coilovers, works emotions 18"
probably like 26psi to keep block happy, on 93 octane.
Power?
Times?
-Ben
Old Feb 23, 2011 | 06:18 AM
  #561
Originally Posted by 2006blkevo9
Evo IX 19000 miles
stock clutch
Ebay FMIC
Titek 02 housing
Walbro 255 pump
Spoolin up COP
Power?
Times?
-Ben
~ 430awhp on 93 (dynojet)
hard to guess at e.t. due to driving/traction but it should mph ~ 117-120mph lifting to shift. The car is light but it has 18" wheels/street tires.
Old Feb 23, 2011 | 03:34 PM
  #562
guest49582's Avatar
How much WHP with this set up:
I have a stock EVO IX MR. What would I make with this set up...
FP HTA Green Turbo
255 Fuel Pump
1000 cc injectors
Buschur TBE
ETS Intake (or AEM)
3 port solenoid
E85
I'm curious what I would make on 91 and e85. Thanks everyone!
Old Feb 23, 2011 | 08:30 PM
  #563
tscompusa2's Avatar
FP HTA Green Turbo
255 Fuel Pump
1000 cc injectors
Buschur TBE
ETS Intake (or AEM)
3 port solenoid
E85
single walbro? might pass 500 on e85 but it will need one of the newer style fuel pumps or a double pump.
91 probably low 400's high 300's. The 3 port should help a lot by maintaining a nice wgdc curve.
The HTA green is a nice turbo.. my numbers above are based on a decent set of cams also.. get yourself some GSC S1 for the green. if not deduct 30whp or so off each number.
Old Feb 23, 2011 | 08:43 PM
  #564
tscompusa2's Avatar
Evo IX 19000 miles
stock clutch
Ebay FMIC
Titek 02 housing
Walbro 255 pump
Spoolin up COP
Power?
Times?
-Ben
what size is the ebay fmic? what is the core width and what are the inlets in diameter?
If i was tuning that car my personal goal as a tuner would be anything over 460.
Add another 15whp for the SD mod.. injectors will be a bottleneck possibly.
Good luck with the car.. i recommend going with a more proven core tho and some 1000cc pte or similar to be safe.
Old Feb 23, 2011 | 08:58 PM
  #565
I inquired about getting a tune from you actually.
What FMIC would you go with?
Old Feb 23, 2011 | 10:23 PM
  #566
Evoleader88's Avatar
Stock block, head
PTE JB 6262 .82A/R
Fullrace manifold
44mm WG
full bolt-on
BC272 cams
valve spring and retainer
ARP headstud
1000cc
ported and polished intake manifold
Exedy triple disc
what power should i expect 28-30psi on pump? e85?
on what dyno?
Old Feb 23, 2011 | 10:42 PM
  #567
tscompusa2's Avatar
i inquired about getting a tune from you actually.
What fmic would you go with?
ets 3.5"
Old Feb 23, 2011 | 10:48 PM
  #568
tscompusa2's Avatar
Originally Posted by Evoleader88
Stock block, head
PTE JB 6262 .82A/R
Fullrace manifold
44mm WG
full bolt-on
BC272 cams
ARP headstud
1000cc
Exedy triple disc
on what dyno?
with those cams? maybe 650 at best? not sure..
make sure you have a huge FMIC also and atleast something
like a magnus v5 for intake manifold.
Old Feb 23, 2011 | 10:54 PM
  #569
oh yea... i got Perrin 3.5" Front mount,
Old Feb 23, 2011 | 11:00 PM
  #570
tscompusa2's Avatar
not good! I went from being stuck to 560whp to 660whp by switching the FMIC from perrin to buschur race 3.8"
The perrin inlets are only 1.8" .. get rid of it asap. Its good for little turbos, but sucks once you need to actually flow serious air.
