How much power will my setup make [Mega Merge]
its a very nice setup bro. But with all that it really depends how the tunner is but over here a setup like that with pump and meth will make over 600 like 28-30 psi and very safe. So u wont be dissapointed at all and will be a mid 10 sec car in the 1?4 mile with good driver!
2003 evo gsr VIII
evo IX turbo (coated and turbine ported by MAP)
tbe
straight pipe
SRI
licp
uicp
ARC fmic
680cc injectors (curently should I go bigger?)
walbro fuel pump
Greddy RZ bov
HKS 272 cams
ported\coated intake manifold
Ported\coated exhaust manifold\
65mm TB
Invidia 02 Housing
on 93 octane @23 PSI
on a mustang Dyno?
what else, besides upgrading to a better stock form turbo, should I do\change?
thanks
-duder
tbe
straight pipe
SRI
licp
uicp
ARC fmic
walbro fuel pump
Greddy RZ bov
HKS 272 cams
65mm TB
Invidia 02 Housing
on a mustang Dyno?
thanks
-duder
If not what kind of gains would that be on a stocker?
How rough is the idle with those?
And IIRC you HAVE to upgrade your valve train with those correct?
Yes you will have to get springs and retainers with the S2s. It is worth it though. Good luck
Mikey
wats u guys.. havent dynoed my car yet but got a street tune till i get to do sum dyno time.. just wondering if u guys might know from experience and knowledge wat kinda power i might be putting down.. my mods r on my sig. and im running 28 psi on pump..
2003 evo gsr VIII
tbe
straight pipe
SRI
licp
uicp
ARC fmic
walbro fuel pump
Greddy RZ bov
HKS 272 cams
65mm TB
Invidia 02 Housing
on a mustang Dyno?
thanks
-duder
tbe
straight pipe
SRI
licp
uicp
ARC fmic
walbro fuel pump
Greddy RZ bov
HKS 272 cams
65mm TB
Invidia 02 Housing
on a mustang Dyno?
thanks
-duder
Ill play haha
Relevant mods
(motor)
Built 2.0
Eagle Crank
Wiseco HD pistons 86.5mm pistons (.40 over)
Eagle Rods
Cosworth rods/main bearings
ARP Main and head studs
3 angle valve job
GSC S2 Cams
Dual valve springs/retainers
STM Oil Cooler
(exhaust/intake)
Billet 6765 .82ar
Full Race Manifold
JMF Intercooler Piping
ETS 3.5" Cooler
Fuel
1000cc injectors
single 255
tuning
stock ecu
Stock Intake mani and throttle body
BTW: Mellon ill be coming to you for tuning in a few months
Relevant mods
(motor)
Built 2.0
Eagle Crank
Eagle Rods
3 angle valve job
GSC S2 Cams
STM Oil Cooler
(exhaust/intake)
Billet 6765 .82ar
Full Race Manifold
ETS 3.5" Cooler
Fuel
1000cc injectors
single 255
tuning
stock ecu
2.3 Stroker, fully balanced and blueprinted
Manley h-beams
Manley forged 100 mm crank
JE 8.5:1 Pistons
Ferrea comp plus valves
GSC S2 Cams
GSC Beehives/ Ti retainers
Ported head, turbine housing, O2 housing (done by myself)
MA Performance Rev3 ported intake
MA Performance ported exhaust manifold
ACL Race main/ rods
ARP main and head studs
Balancing shafts removed
1000cc injectors
Tommi Makinen Edition Turbo w/ 10.5 hot side
Tommi Makinen Edition Intercooler
3 in TBE, no cat
ARC Super Induction
93 Octane, going to try to get 24 psi out of the turbo
Manley h-beams
JE 8.5:1 Pistons
GSC S2 Cams
ACL Race main/ rods
1000cc injectors
3 in TBE, no cat
ARC Super Induction
Hello EVOpeopos !
Please guesstimate hp/tq numbers ~!!!!
current mods are
3" Turbo back x-aust with test pipe
Perrin silicone short ram intake with foam filter
ams LICP
hks 272/272 cams
ported megan 02 housing
walboro 255 lph pump
boost peak at 25 psi
tuned on 93 (street)
also what kind of gains could I get with a Evo 9 turbo, and ported header ?
thanks peoples !
current mods are
ams LICP
hks 272/272 cams
thanks peoples !
Ill play haha
Relevant mods
(motor)
Built 2.0
Eagle Crank
Eagle Rods
3 angle valve job
GSC S2 Cams
STM Oil Cooler
(exhaust/intake)
Billet 6765 .82ar
Full Race Manifold
ETS 3.5" Cooler
Fuel
1000cc injectors
single 255
tuning
stock ecu
Relevant mods
(motor)
Built 2.0
Eagle Crank
Eagle Rods
3 angle valve job
GSC S2 Cams
STM Oil Cooler
(exhaust/intake)
Billet 6765 .82ar
Full Race Manifold
ETS 3.5" Cooler
Fuel
1000cc injectors
single 255
tuning
stock ecu
Manley h-beams
JE 8.5:1 Pistons
GSC S2 Cams
ACL Race main/ rods
1000cc injectors
3 in TBE, no cat
ARC Super Induction
Manley h-beams
JE 8.5:1 Pistons
GSC S2 Cams
ACL Race main/ rods
1000cc injectors
3 in TBE, no cat
ARC Super Induction
