How much power will my setup make [Mega Merge]
Old Sep 13, 2010 | 03:14 PM
  #421
KX250Fmotoracer's Avatar
Originally Posted by Mellon Tuning
not much data on that turbo, I'd guess 400 possibly. Hopefully you just forgot to mention the walbro pump you're going to need
The Mak should be very similar to an Evo 8 stocker w/ 10.5, but spool ~500-700 RPM faster. I'm trying to build a good auto-x car/ weekend play car, but I want it to LOOK stock. And yea I'm going to upgrade the pump as well! I really want to upgrade to E85, but the closest pumps to me are about 30 mins away
I'm building the car from the ground up (Mirage to Evo VI TME conversion) so I get to pick all the good parts the first time around
Old Sep 13, 2010 | 06:11 PM
  #422
Randog's Avatar
400ish with 93/meth with the stock cams holding you up, no mention of injectors
what injectors would be good? wont be doing cams for now.
Old Sep 14, 2010 | 06:52 AM
  #423
dgrumpys's Avatar
bump for some help with hp/tq numbers..... I know my setup is pretty generic/ wussy/ cheap etc. but Im still making payments on this car, ( mommy and daddy never help me out )
My real reason for posting is im looking at upgrading turbos ( depending on price ) and want to know tuned hp/tq numbers when upgrading to evo 9 turbos/ported mani's .
Im either going to get a fp green or evo 9 turbo depending on price vs power
Old Sep 14, 2010 | 07:09 AM
  #424
Mellon Racing's Avatar
the more meth injected the smaller the injector you need but you could go up to 1000cc without sacrificing driveability in a standard low impedance injector. You could probably get away with a smaller injector but the price is about the same and you'll have some wiggle room for future mods or if you decide to ditch the meth kit (many people do)
Old Sep 14, 2010 | 07:12 AM
  #425
no idea what car you have but since you're talking about an evo 9 turbo as an upgrade I'd have to think you've got an evo 8. Going from an 8 turbo to a 9 turbo isn't worth much but they are cheap as hell. If you can pick up a used FP green that would be a worthwhile upgrade which has the potential for up to 400 on pump. I've had some freak customers do 425 but don't expect it.
Old Sep 20, 2010 | 07:03 PM
  #426
ddb's Avatar
ddb
I'd just like to know what can be pushed out of my current setup.
I recently had a rod bearing failure on my engine
But found out that my engine was in fact a 2.3 stroker.It was a rebuilt evo
So basically i have
Stroker 2.3l from JAM no BS
HKS 264\264 cam
Greddy adjustable cams gear
Brian crower spring\reteiner
Stock turbo evo 8 9.8 hotside
Injen TBE
Injen Intake SRI,upper lower Piping
Stock intercooler
Grimmspeed EBC
JDM 3 Bar map sensor
So what is the best\max boost reliable i can run and what hp can be expected?We only have 91 octane here thanks
Old Sep 21, 2010 | 12:27 PM
  #427
So basically i have
HKS 264\264 cam
Injen TBE
Stock intercooler
Grimmspeed EBC
I'd keep it around 25psi and dial it in for 91 octane, that's pretty odd combo with the built 2.3, mild cams and stock fmic. This is a wild guess but I'd say 350ish
Old Sep 21, 2010 | 12:52 PM
  #428
ddb's Avatar
ddb
I know it is quite a odd combo eventually i'll upgrade the intercooler it's just that i have a some money to spend on the car for now just to have it top shape after that i'll upgrade intercooler and turbo and for the cams they were already on it. Has i said it is a rebuilt car because it has been salvaged and the first owner kept is turbo after the accident and put back the stock one.
Now i i know what i have where i'm going.. Thanks for your help... by the way what would be the next logical upgrade... thanks again. Oh forgot i also have a walbro.
Old Sep 23, 2010 | 09:34 PM
  #429
Jim3142's Avatar
Well, hopefully you guys can give me somewhat of a baseline so I can know what to expect. Was thinking about eventually going to GST Motorsports to get my Evo tuned on their Mustang Dyno. Here's what I was thinking about doing:
Walbro 255
Perrin intake
Perrin 3.5" intercooler
ETS LICP
Apexi AVC-R EBC
Greddy Ti-C catback exhaust
Invidia O2 housing
91 Octane( I'm in between NorCal and Socal)
Basically, I'm looking for 300 WHP. Nothing major, just want something more than stock and fun to drive. I'm not totally set on the exhaust choice, was thinking about a downpipe. Also, the intercooler's for the summer heat we usually get, although this year was considered relatively cool as we didn't get 21 days of 100+ degree heat in July haha. The car's a daily driver and will be auto-x'd, along with some spirited driving in the mountains .
Old Sep 26, 2010 | 08:59 AM
  #430
bevolucion's Avatar
Ok Let me post running 93 oct
2.3 stroker
272 kelfords
ported intake
hta3582
27 lb boost spiking at 32
straight 3" tbe
255lph walpro
2 3/4 fmic greddy( just ordered 4" ets with short route uicp) hopefully can run 30lb
self tuned
peak timing at top loads 0-2*
what should I be seeing for whp and torque?
I have never been on a dyno
Old Sep 27, 2010 | 11:56 AM
  #431
fmic
then the next level would be turbo/injectors and bigger cams if you want the most the turbo has to offer.
Old Sep 27, 2010 | 11:57 AM
  #432
2.3 stroker
272 kelfords
ported intake
hta3582
straight 3" tbe
255lph walpro
self tuned
475-525 on a dynojet with a good tune
Old Sep 27, 2010 | 10:02 PM
  #433
JohnBradley's Avatar
2.3 stroker
272 kelfords
ported intake
hta3582
straight 3" tbe
255lph walpro
self tuned
If you can make it work without knock, we have seen 510whp at 26 for reference. I cant remember if that was stock Intake manifold or Magnus however. There is a possibility it was with the Magnus, but my gut tells me it was a ported stocker.
Old Sep 28, 2010 | 08:36 AM
  #434
milford's Avatar
stock evo 8 block
fp black with 84 mm cover
titek o2, catless 3inch
fp maf tube
nisei intercooler and pipes
double pumper
ID 2000s or new blue max
gsc s1
E85
looking for an idea of what i will make on a mustang .
thanks in advance
Old Sep 29, 2010 | 11:52 AM
  #435
EVO196's Avatar
I would like to know too...
What I have now is in my sig.
What I'm going to install:
Old fp green, gonna port the hotside
gsc S1
ported stock ex. manifold
megan o2, port it & open hole up more
I'm hoping right around the 400whp mark....
cheers
