How much power will my setup make [Mega Merge]
Old Nov 9, 2013 | 04:51 AM
  #1096
Enyth's Avatar
Originally Posted by Section518EVO
Wasn't thinking about it at the time lol. Figured I could get some good feedback on here!
You will always get good feedback from STM!
You just wanted more answers!
Old Nov 9, 2013 | 05:30 AM
  #1097
PhantomBlackEVOX's Avatar
Veteran: Army
Yeah your right lol STM has been extremely good and helpful
Old Nov 9, 2013 | 05:44 AM
  #1098
Enyth's Avatar
Yeah i figured, haha!
Yeap, they're good peeps!
Well if i were you, just go E-85 and you'll be at 465-480 no problem. Do couple more bolt ons and you'll get well over 500! You already have the injectors, fuel pump, and assuming you have the 3 port, so you're good on the E-85 part.
Old Nov 9, 2013 | 06:46 AM
  #1099
Veteran: Army
I'm not certain what you mean by 3 port. But I'm waiting to get my cob access port so I can have an E85 tune and a 93 tune. but anything 450whp+ sounds good to me!
Old Nov 9, 2013 | 08:04 AM
  #1100
EmeryatSTM's Avatar
Please put head studs in your car before I tune it. If the head gasket goes because of that its going to cost you a lot more than its worth. Also, I will be using ecuflash to tune the car. No need for anything accessport and we will certainly not be using a 3 port EBC. We ONLY use manual boost controllers.
As for numbers, The sky is the limit really and depends on how far you want to push it. I would suggest sticking around the 370 mark but we will know more once its on the dyno.
Thanks
-Em
Old Nov 9, 2013 | 08:09 AM
  #1101
Veteran: Army
Thanks
-Em
Well your the tuner so I'm sure you know whats best for the car. I'll give the shop a call on Monday about the head studs!
Old Nov 9, 2013 | 09:19 AM
  #1102
STM Tuned's Avatar
Just call me now!
Here till 5.
Old Nov 10, 2013 | 12:22 PM
  #1103
211Ratsbud's Avatar
Hey guys, I have a fairly modified 9 that Ive been trying to get a reasonable grasp on its potential.
Skunk2 intake manifold ported anda full blown 70mm tb
S2 cams
FP 71hta (51lb/min compressor stock turbine) with the 84mm cover and intake tube
3" downpipe - back kitten killer
Megan o2 housing
JMFab 3.8" garret core intercooler with STM UICP and unknown lower
Im running 93 oct fuel, and I have virtual dyno'd between 425-440 pretty consistently in Dynojet mode (1.09 CF I believe). A secondary goal will be able to go very low 11's @ 300-500 ft raw elevation.
I really want to be around 400 on STM's mustang and I feel like Im probably 350-380 there. Whats your guys best guess? 22-24 is about all I can muster for boost up top and I don't like boost spikes that spike torque so im not willing to go much higher. Stock bottom end and a 3port is what Ive been tuning with. I think to reach my goal I need less turbine back pressure as its probably getting pretty high up top. Ive been contemplating having FP clip my 71 when it gets rebuilt.
Old Nov 15, 2013 | 06:08 PM
  #1104
Werdna06's Avatar
I have a 9 mr that i'm about to put some fresh parts on and get tuned if there is something i might be lacking in that isn't a budget killer let me know what i might could add.
Stock turbo
Stock intercooler
ETS short route intercooler piping
Stock block and internals ( that i know of)
3" exhaust down and back
Megan Racing Test pipe
Megan Racing Exhaust manifold
Walbro 255
Unknown clutch but i'm quite sure it's aftermarket because it chatters like a btich if i'm trying to go under 2k rpms
3" JM fab intake pipe with 5"dia x 6.5" length k&n intake filter
Hallman mbc
93 octane
24 lbs boost
Old Nov 21, 2013 | 11:39 AM
  #1105
LOLZFWD's Avatar
Finding anything comparable to the same info on my build has been challenging to find results, so I thought I'd share and see some thoughts.
'04 WW RS
self built 2.4LR
Manley turbo tuff series billet 100mm crank
Manley turbo tuff series I beams, HD pin, ARP625 bolts, 156mm length
Manley forged pistons, ceramic coated, 9:1 87mm bore (calculated static compression of 9.23:1 with head cc, hg, and decking calc'd in)
ACL race series bearings
Girdle doweled and ARP studs
Cosworth 1.3mm MLS headgasket
ARP L19's
GSC R2 cams (274 prof, 12mm lift)
AEM adj. cam gears
GSC 5041 high rev beehive springs and retainers
MAP nitrided SS oem sized valves
Curt brown ported IM-powder coated, thermal spacer
Curt brown ported EM-ceramic coated
Curt brown ported, ceramic coated EVO 9 turbo
True 3" exit recirc o2 housing (custom)
True 3" flanged DP (custom)
Kiggly HLA
65mm Ported polished TB
Buschur DP
ID1300cc injectors
E85
Grimspeed 3-port + Grimspeed MBC (hybrid boost)
VRSF IC
ETS stock route piping
3" SD intake
Looking for as much power I can get, as soon as i can get it, with a BROAD powerband. Mainly autocross/RR street car, with occasional drag stip. Like to run MAXEffort class at buschur shootout this year. More then likely go to a fp HTA BB green/red in the future.
Old Nov 21, 2013 | 11:50 AM
  #1106
joey0480's Avatar
typo!
Old Nov 26, 2013 | 09:30 AM
  #1107
Shinzon's Avatar
211rats , im guessing 400-420 dyno jet
Old Nov 26, 2013 | 09:32 AM
  #1108
Shinzon's Avatar
Stock turbo
Stock intercooler
Walbro 255
Hallman mbc
93 octane
24 lbs boost
injectors and intercooler
Old Nov 26, 2013 | 09:36 AM
  #1109
Shinzon's Avatar
'04 WW RS
self built 2.4LR
ARP L19's
AEM adj. cam gears
Kiggly HLA
Buschur DP
ID1300cc injectors
E85
VRSF IC
3" SD intake
damn! almost the same build as mine except i have a bigger turbo and smaller injector lol. i guess 400-450 whp and torque. but that tq is gonna come in very very early, and loose breath after 6k rpms.
Old Nov 28, 2013 | 02:33 PM
  #1110
anwkid's Avatar
Hey guys im just about ready to drop in my new build. Im looking for some awesome torque numbers low in the band but im afraid i may have sized the turbo too big.. Anyways if you guys have any idea on what I can expect power wise and what my possible bottle necks will be Id be interested to hear it! Thanks in advance!
03 GSR
self built 2.4LR
Wiseco forged pistons, hard annadized, ~10.5:1 87mm bore
Cometic MLS headgasket
Stock head and cams for now
ARP L19's
AEM adj. cam gears
Full 3"-3.5" Exhast (custom)
ID 1450cc injectors
E85 + water/meth if needed
HTA 3582
XS power tubular manifold
44mm external wastegate
AMS IC
stock route piping
4" SD intake
