View Poll Results: Which ACT Disc Locked you Out?
Street Disc w/ heavy PP
20.30%
Street Disc w/ Extreme PP
16.54%
6 puck or 4 puck w/ Heavy PP
15.04%
6 puck or 4 puck w/ Extreme PP
6.77%
No lock out issues
41.35%
Voters: 133. You may not vote on this poll
ACT Lock Out Thread
Old Apr 6, 2011 | 08:39 PM
  #61
boostedwrx's Avatar
MB7-HDSS, 8k rpm shifts, no lock-out. It's fairly new though also.
  #62
Pal215's Avatar
After the install of my xtss, stock flywheel I had lockout issues. After 1000 miles it went away. This may sound stupid, but my lockout issues went away even more after i started shifting faster.
Old Apr 7, 2011 | 12:51 AM
  #63
fightex's Avatar
my XTSS + street disk locked me out all the time to the point where it made me doubt my driving ability
then i saw the light and switched to a Quartermaster twin and the difference was night and day.
sure the QM is a little noisy sometimes, but the pedal's light and organic FEEL, the short stroke and the ability to bang gears when you need to =
before nay sayers jump down my throat, get this - the ACT was installed by a well known shop in SoCal, so i doubt its install error. i also had all the bushings (both underhood and shifter base), clutch line, Amsoil tranny fluid and adjusted the clutch properly but to no avail, so
Originally Posted by EmeryatSTM
Who here runs 11's with an ACT? IF you do what is your MPH? It seems that most people will not experience lock out because they simply do not shift fast enough.
-Em
this
Old Apr 22, 2011 | 03:25 PM
  #64
Contacted ACT over 2 weeks ago, via email, noting the lock out issue & their system noted a 24 hour response to my question.
Never heard from them
Old Apr 23, 2011 | 01:01 AM
  #65
DREVO978's Avatar
i have an act hd 6 puck unsprung goin in next week.. my friend bought a used act for his evo.. hd with street disk.. he runs a gt35r at 35psi daily.. races at the track.. launches everywhere.. and now goin for his 2 yr with the same used disk with no issues.. at first he had lock out issues but he adjusted and adjusted till he got the sweet spot and ever sence no more issues.. so must be an adjust thing that sum people aint doing right.. lets see how my install goes..
Old Apr 23, 2011 | 08:32 AM
  #66
dastallion951's Avatar
not for anythin but most of you guys that buy the ACT clutch buy the wrong model, how many people buy the XTSS theres ur problem right there im on my hdss with prolite flywheel, and to boot all i have is upper and lower SS clutch lines.. thats im sure most of your problem, dont rev to 8k if the clutch wont handle it.
Old Apr 23, 2011 | 08:57 AM
  #67
ROGERV's Avatar
ACT-XTSS with solid hub street disc and steel braided clutch line
No lock outs here, shifting 7-8k .
Old Apr 23, 2011 | 09:16 AM
  #68
boostedwrx's Avatar
I broke mine in on the dyno too - not sure if that made a difference
Old Apr 23, 2011 | 01:00 PM
  #69
WolfsFang's Avatar
Getting the XTSS installed. Once i break it in we shall see. I think its how its installed that causes all the lockout issues.
Old Apr 23, 2011 | 01:10 PM
  #70
Boosted Tuning's Avatar
Originally Posted by evodom1
Hi! Now I do afraid to install this clutch again!
So the story is...
evo9 car (6-speed) with almost 40k km - "stock turbo + m2 cams setup) - several sinle disk cluthes - oem, exedy stage 1, rallyart ceramic etc - no problem at all - high rpm shifting over 7.5k...
And, I got it...ACT XT pressure plate. Install it with oem exedy organic disk - lockout after 6k - lots of adjustments - no result - just went a little bit higher than 6.5k...drive this conf for about 1k km - got vibration in cluth pedal and a little bit later - broken crankshaft (stock 9!)...after engine rebuild (to 2.3L) installed again this combo - ACT XT+OEM disk - got lockout, switched to stock pressure plate -NO LOCKOUTS but...too much torgue (2.3L) killed organic disk...switched to ACT HD+oem disk - some lockout after 7k - but mort or less acceptable (the stroker - I did not run over 7k)...and...after 3k km I felt the same vibration on my clutch pedal...the story repeated - №5 crankshaft bearing almost destroyed and crankshaft "dead"...
Now I am 99% sure the reason is ACT (or at least combo with OEM disk).
How can you blame the ACT pp when you never used a ACT disk with it? You should have ran the ACT pp with an ACT disk, not with an exedy disk and an OEM disc.
Also crazy vibration and destroying crankshaft most likely means incorrect install and/or incorrect balance of the disc or flywheel.
Old Apr 23, 2011 | 01:23 PM
  #71
Ill add that I have the ACT HDSS w/ Streetlite flywheel. No lock out at all, shifting at 8K. FP BLACK, Avid front mount, Short shifter, Stock clutch line, stock underhood bushings, stock shifter base bushings.
Old Apr 23, 2011 | 02:17 PM
  #72
RazorLab's Avatar
I've used probably 6+ ACT clutches on my personal cars over the last 15 years and never once had the lock out problem.
Old Apr 23, 2011 | 02:41 PM
  #73
GgreyEVOIX's Avatar
Did you ask the guys who installed it? RRE did my ACT clutch and flywheel 2 years ago and I've never had a single issue with it, no lockout or any other issues and I shift @ 7500
Old Apr 23, 2011 | 08:32 PM
  #74
WolfsFang's Avatar
i also had a ACT 2100 in my eclipse GSX and it was fine with no problems.
Old Apr 24, 2011 | 07:46 AM
  #75
id say more times then not its due to install error, or driving error, like another .25 of a second with clutch down while shifting sometimes is all it takes, some people try bangin the gears, and might sound like bs, but the way you hold the shifter and the way you shift it can make a difference too.
EvoJoeIX
Dec 14, 2021 09:25 AM
zoso
Jul 22, 2015 04:43 PM
FameEvo
26
Apr 17, 2012 11:01 AM
12secDD
Mar 30, 2012 08:51 PM
Nomad4g63
Nov 16, 2010 10:37 PM
