What helps a turbo spool faster
You mean exactly the opposite of what you are stating, right? Keeping the wastegate flapper valve shut and tight on its seat will net the quickest spool, right?. Whereas, keeping the WG open wider and longer will give you the laziest spoolup.
That right adding timing will help it spool but not so much that knock is introduced. Best to tune this on a dyno for max torque in the middle and max hp up top.
