4g63 block problems ...
Old Jan 23, 2010 | 04:27 PM
rh9's Avatar
rh9
Unhappy 4g63 block problems ...
hey guys,
I've got a 2.3 4g63 on my evo7, the thing is I took off the head to change the gasket to a thicker cometic gasket to lower the cr, I noticed a tiny scratch on no.3 cylinder wall, It can be seen and felt only when I move my finger nail on top of the line
Took the engine apart to check it out, I got new piston rings and now wanna assemble the bottom end, tried to source another block and rebore, but could not find any in the area sadly
what would happen if I reassemble the the short block with the scratch ? blow by ? compression ring seal problems ? My compression was perfect on this cylinder before de assembly
I really don't know what to do now..advice needed
Old Jan 23, 2010 | 08:23 PM
5LEEPERISAH23I's Avatar
that really suxs
Old Jan 24, 2010 | 03:21 AM
rh9's Avatar
rh9
and ...?
Old Jan 25, 2010 | 07:45 PM
WHTEVO's Avatar
Hopefully you didn't take your engine apart because of the mark at the top of the cylinder bore where the rings don't touch. If you went as far as taking it all apart and getting new rings etc, might as well have a machine shop re-hone it or at the minimum buy yourself one of the DIY ones. Good luck.
Aaron
Old Jan 26, 2010 | 08:21 AM
rh9's Avatar
rh9
The line goes all the way from the bottom of the block to the top !
I'm looking hard for another block now but still no luck
Old Jan 27, 2010 | 07:50 AM
M4Lki3r's Avatar
Veteran: Marine Corps
Can you hone it out or is it scored so deep that it will change the actual bore?
A bigger question may be: Why is it there? What caused it?
Old Jan 27, 2010 | 12:09 PM
MitsoKid's Avatar
hmm interesting. I just pulled my block. I have a ring land completely broken off and my rings are shot but my cylinder walls still look new.. I wonder what would have caused that?
Old Jan 27, 2010 | 12:38 PM
rh9's Avatar
rh9
A hone job won't fix the problem, I just checked with the workshop
I'm gonna change the sleeves locally
Old Jan 27, 2010 | 12:54 PM
boosted2x2's Avatar
i had a similar issue when i had my twin turbo z. if you cannot find another block see if it is possible to have your machine shop sleeve the one cylinder that is damaged.
Old Jan 27, 2010 | 12:59 PM
xRoguex's Avatar
pictures are required for any real help.
Old Jan 27, 2010 | 03:53 PM
Walt's Avatar
You could get it bored out then run oversized pistons..
Old Jan 28, 2010 | 01:19 AM
rh9's Avatar
rh9
True I could, but I just got these wisecos and I can't return them back to the supplier
I'm resleeving the block and will let you know how it goes in few days
Old Jan 28, 2010 | 01:46 AM
disaster646's Avatar
y not sell the wisecos on here.. and get the size u need.. if u have to go bigger..
Old Jan 28, 2010 | 07:34 AM
rh9's Avatar
rh9
Cause I'm on the othe side of the world bro BAHRAIN !
11secEVO7
20
Jan 28, 2017 10:27 AM
maperformance
Jun 25, 2014 09:44 AM
9GUY9
327
Dec 17, 2013 09:16 PM
Jacks Transmissions
Jacks Transmissions
Jan 4, 2013 12:26 PM
kelvinTME
May 20, 2012 07:45 PM
