Rear Diff Options - Power Oversteer Found Here
front end feels fine, there's no power being delivered through it. the ACD on the other hand gets pretty pissed.
how so?
it does what you can see at 1:19 in this video right before i shift.
http://www.youtube.com/watch?v=gAM0EO7poTo
...that might have been both back wheels off the ground. the wheel speed data showed a couple hops with both back tires spinning the same speed and spiking.
does the car wobble left to right when that happens? Feels like you're being shaken inside the car?
My car does a very similar thing at PGP and I haven't been able to figure out what the hell it is.
Only does it when I'm hard on throttle coming out of a corner. It tosses me around inside the car.
EDIT: nice two footing!
I've had that very same thing happen a couple times on my 03 w/viscous center. Not sure it's ACD related. Sure feels crazy.
Also totally agree on the front inside wheelspin. It definitely occurs. If you watch video around 35 seconds you can hear the rev limiter pop, then go silent and pop again. The trend with short stroke dampers certainly doesn't help the situation. I have spoken with Jon @ TRE about front diffs. What he basically said was that the clutch type front diffs are fantastic in the dirt where the lockup is tolerable on turn in and totally necessary on exit. When used on asphalt they don't work very well. He's had customer's swap back to torsen (OEM, Quaife, etc) from clutch type. I was really interested in trying one but my car has been sitting for a year now.
http://holunfie.blogspot.com/2007/04...-diff-and.html
All,
As for the GSC 40/60 Center Diff I have one. With the lower power levels on my car (298 hp/320tq, dynojet) it was very subtle, but did help the car to rotate. There was a more profound effect with the TRE rear diff though once I added it. Everyone I knew that ran one liked it. Don't know of anyone running one with ACD though.
If you're interested pics are here:
http://bp1.blogger.com/_rOf08BWxyfo/...h/100_3575.JPG
John
I did the install myself. Just need new bearings for the diff and probably shims for preload unless the original can be reused. If you damage the speedo gear when removing that will be another part. Figure less than $100 in parts.
Kyooch,
The center diff has 2 parts. The acd or viscous coupler which are in the TC and the actual differential which is in the transmission. This diff replaces the portion in the transmission. It also comes with a billet "spool" if you will that would replace the vc. Most people don't use this part as it doesn't allow any slippage between the frt and rr wheels.
John
Kyooch,
John
Kyooch,
John
Kyooch,
John
I run a Quaife front diff in my RS. The car doesn't make 500 ft lbs of torque at 4000 rpm like project white did. I've had no front wheel spin in the RS but I'm guessing because of the power band. As a aside note, no change in 60' times going with the Quaife over the stock RS front limited slip.
Just adding information to the topic.
Not sure if I mentioned, I finished my rear diff, ended up building a 12 disc set up instead of just an 8. Very interesting what you can learn DOING something like that. I've got a few spare rear doffs, if this works I'll set my other spares up too.
After reading the past few pages it seems a 1-way clutch style front diff may be a solution to this. . .
EVOlutionary
Read up here:
https://www.evolutionm.net/forums/ev...ntre-diff.html
