Rear Diff Options - Power Oversteer Found Here
Old Oct 5, 2010 | 08:29 AM
  #346
kyoo's Avatar
Going with these arguments wed all still be running mobil 1 in our motors too right?
Old Oct 5, 2010 | 08:41 AM
  #347
GG06MR's Avatar
Mobil 1 pays manufacturers to be their recommended engine oil supplier. That's evidenced by their logo on the oil cap. Diaqueen, a Mitsu product, not so much.
Old Oct 5, 2010 | 08:48 AM
  #348
David Buschur's Avatar
I've been using shock proof heavy in the rear diff of the Bish for quite a few years. The wear in the rear end was unbelievable, the abuse this car has seen and the power it makes. The new rear diff I just built for the car I put the same shock proof heavy in because of that. I don't know how the diff is going to act, I'll find out soon.
Old Oct 5, 2010 | 06:19 PM
  #349
EVOlutionary's Avatar
Yes, if the engine was still stock (mine is) and Mobil 1 had not changed their formulation that reduced its performance. . .
I've run Mobil 1 on my motor for 8000 miles (90% racing), banging off the revlimiter at 8000RPM all the time, making 400+TQ on a Mustang dyno on the stock block for 4 years. Seems to work . . .
Just switched to AMSOIL race oil on my last oil change after I read about Mobil 1 changing formulation. As far as I know - Diaqueen is still the same great stuff it has always been. . .
Old Oct 5, 2010 | 06:29 PM
  #350
SWOLN's Avatar
Please don't turn this into another oil pissing match guys. I really like this thread...
Old Oct 5, 2010 | 07:33 PM
  #351
kyoo's Avatar
my apologies
anyway, after a long day i'm finally home. i put the amsoil 75w110 severe gear into the diff with some additional friction modifier - car is running perfectly, not a PEEP from the rear diff which is crazy considering it used to sound like someone was hitting it with a baseball bat everytime i made a low speed turn.
if this doesnt hold i will definitely switch to diaqueen, but for now i'm pretty happy with the result
Old Oct 5, 2010 | 08:50 PM
  #352
GoTopless's Avatar
Can someone confirm that the TRE diff is legal for SCCA's STU auto-x class, for a 2006 Evo IX GSR?
Cut&Pasted from rulebook...
STX, STU, STR – Only standard (as defined in Section 12.4) limited
slip differentials (LSD) are allowed on AWD vehicles. For AWD
vehicles that did not come with any type of limited slip differential
(including center differential or transfer case), a single aftermarket
LSD may be added. 2WD vehicles may use any LSD unit.
Old Oct 5, 2010 | 08:54 PM
  #353
kyoo's Avatar
thanks for this! i actually thought it WASNT legal in stu, so this is news to me
edit - oooo i missread this. yea it is not legal for evos. the car comes with three lol
Old Oct 5, 2010 | 10:15 PM
  #354
R/TErnie's Avatar
The paraffin's in the heavy weight shock proof won't contribute well to generating friction between the plates.
But it will protect the ring and pinion.
I would run the Redline 75/140 NS and then buy a bottle of friction modifier.
Start running it without the friction modify and add until you end up with a livable sounding rear end.
Old Oct 5, 2010 | 10:49 PM
  #355
griceiv's Avatar
TRE's STU legal rebuild is legal. The max lock is not legal at all.
Old Oct 6, 2010 | 05:45 AM
  #356
4cdndctn's Avatar
This is correct
Old Oct 6, 2010 | 06:50 AM
  #357
Bassicfun's Avatar
Shep also has an STU legal rebuild/refresh, all within OEM spec (similar to TRE)
Old Oct 6, 2010 | 09:46 AM
  #358
kyoo's Avatar
thread got unstickied - why?
Old Oct 6, 2010 | 02:21 PM
  #359
chaotichoax's Avatar
please leave thread stickied
thanks
Old Oct 7, 2010 | 04:09 PM
  #360
Edited because there's not need for me to hurt the sales of other shops..............we don't currently even offer this service here.
