Rear Diff Options - Power Oversteer Found Here
Old Oct 13, 2010 | 07:30 AM
  #376
03whitegsr's Avatar
Originally Posted by kyooch
as far as i know the 03 8's had an open front lsd with viscous center diff. only difference is that the 9 has a helical lsd in front and active center diff. did you have a rsb or something? maybe the overall grip levels are higher with the 9, and that with the active center diff managing the power breaking loose may not be as easy? otherwise i haven't heard of anything like this.
I think the '03s came with different alignment specs from the factory then all the other years. My car has always been tail happy on street tires. I remember test driving an '06 RS from the dealer and was surprised how different it handled compared to my '03. Felt like a completely different car. It had more grip overall, but didn't have the same ***-out attitude of my '03.
Still wish I had traded in my '03 for that '06 RS.
Old Oct 14, 2010 | 05:02 AM
  #377
4cdndctn's Avatar
I just came back from 2 days at Thunderbolt - as a reminder I have the ACD flash and a freshened Shep rear diff. I was suffering a very odd and annoying binding issue on tight turns that wuld cause me to NOT want to apply throttle until the wheels were nearly straight. The Shep rear diff was my last hope...
... The binding is now 100% gone. Through turns 9 and 10 (Jersey Devil and Octopus Head) I have zero binding and can take the racing line which is unusually tight.
The configuration run included using the second chicane, here's a brief run down of behavior with lap times of 1:35-1:40 depending on lines I was trying...
T1 - neutral
T2 - chicane - car lightened on blind apex and oversteered slightly
T3 - (a/b/c) - Somehow this became a straight line by day 2
T4 - FAST and neutral
T5 - my worst turn (a little early on turn in) and throttle oversteer every time
T6 - FAST and neutral
T7 - slight throttle oversteer
T8 sweeper - neutral to mild throttle oversteer (used to be understeer). I punched it here 2x to try some different lines and had 2 saves, one which yielded corner worker applause as I was about 80 degrees and managed to recover just to go about 30 degrees the other way and recover again
T9 - mild throttle oversteer
T10 - mild throttle oversteer
T11/11A - Straight on the race line and throttle oversteer not on race line
T12 - (non-race line) heavy throttle oversteer on WOT and very stable
Verdict? My VIII now acts much more like a full track setup XMR with the electronic goodies deactivated. Throttle oversteer is present beyond just neutralizing understeer and it may require some people (like me) to relearn the car's behavior. Despite the cost, this is a big change in handling.
This is not for everyone, but those would like to reduce understeer have a viable option.
Because I think my rear diff may have been extremely worn, it's hard to determine the benefits of the ACD flash vs the modded rear diff vs the combined result. Personally, I'm very happy with the combined result!
Old Oct 14, 2010 | 08:16 AM
  #378
R/TErnie's Avatar
glad to hear the rear diff is working for you too!
Old Oct 14, 2010 | 09:10 AM
  #379
kyoo's Avatar
T1 - neutral
Awesome review as always - it's great to hear the rear diff fixes the binding issue from the ACD reflash - sounds like the combo is the best way to go.
Hopefully more and more people will see why I'm encouraging this mod so much!
Old Oct 14, 2010 | 11:33 AM
  #380
SWOLN's Avatar
T1 - neutral
Nice feedback. Can you offer up more information on your suspension and settings for the alignment, what tires ect? Have you changed the suspension setup since your installation of everything?
nice
Old Oct 14, 2010 | 05:24 PM
  #381
Graphic's Avatar
Originally Posted by R/TErnie
Ah but you see... being 5'6" myself and most of my weight being low set... gives me a cog advantage over you tall people. therefor I will not lift inside front and lay rape cakes all around the corners!
haha. gotcha.
Haha awesome, that's what I'm talkin about! I'm 5'8" 163lbs. Short man high five lol
Old Oct 14, 2010 | 05:26 PM
  #382
sir monster's Avatar
I'm going for a 1.5 rear diff and the only one available here is a KAAZ SuperQ. Appreciate feedback on this.
Old Oct 14, 2010 | 05:32 PM
  #383
Graphic's Avatar
Now I don't know what to do anymore.. Voltex rear diffuser or rear diff
03' VIII: Let’s say I buy a shep rear diff and install it. How does the stock front diff feel? Does it understeer? Is this an item that makes a huge benefit for autox\handling as well(the front diff)? I haven’t seen too many posts about the 03's on here. Basically is it worth changing vs the many other parts I could modify on my car?
Also on this rear diff does it make the same huge benefit on the 03 with the stock TC? I read in this thread that the 03 was already tail happy by a previous poster.
The car has coilovers, caster camber plate and 300whp. If this helps.
Old Oct 14, 2010 | 07:30 PM
  #384
kyoo's Avatar
never heard of it - no cusco or carbonetics? i'm sure you could get one shipped. though, it's probable the kaaz will be fine
Old Oct 14, 2010 | 07:33 PM
  #385
kyoo's Avatar
it does make a huge benefit for auto-x, unless you're trying to stay in a particular class. It will definitely make a bigger difference than a voltex rear diffuser. the car will power oversteer.
i mean the parts you "need" to get really depends on what your wants are. everyone who got the diff in this thread got it because they were tired of the corner exit understeer that evos suffer from
Old Oct 14, 2010 | 07:52 PM
  #386
Thanks kyooch. Shop here giving me a really good deal on the 1.5 KAAZ. Website says no break-in required and SuperQ = quiet.
Old Oct 14, 2010 | 07:53 PM
  #387
kyoo's Avatar
let us know how it goes! i'd still give a few hundred miles before i really lay into it, no matter what they say
Old Oct 14, 2010 | 08:03 PM
  #388
Will do! Might do the install next week and have a few trackdays planned
Old Oct 15, 2010 | 12:21 PM
  #389
4cdndctn's Avatar
nice
I'm on JIC FLT A2's/ 0 toe / med-aggressive camber / BFG R1s (265/35/17). I haven't changed my suspension settings since the install.
I'll be at the Nasa event at NJMP in 2 weeks for those that will be in attenedance...
Old Oct 15, 2010 | 06:41 PM
  #390
kyoo's Avatar
Would you say the acd reflash and rear diff is too much oversteer? Did you run in tarmac street or rain?
