HTA green or red... i cant decide!!
Old Feb 17, 2010 | 08:40 AM
  #91
black_beauty's Avatar
results of HTA Green Dyno! I'm in the same boat lol Green or Red? Black is not for me i dont need to make 600+hp...
Old Feb 17, 2010 | 09:01 AM
  #92
Timmay81's Avatar
Originally Posted by fromWRXtoEVO
If you are like me which fast spool is absolutely imperative I would choose the HTA green over the red. There is an exception to that(only my opinion), that would be if you have a larger displacement Evo.
If someone ever offere a turbo with varioable geometry blades that would be your choice, unfortunately there is not such thing for Evos but there are for Porsche and VW in Europe.
Again, my suggestions would be HTA green by a long shot. I would also suggest getting it ported and get your manifold ported, IC pipes and a high flow air filter with a good air pipe intake(Perrin).
Carlos
Perrin is overpriced garbage imo. Im willing to bed that the red only spools a few hundred rpm slower than the green so i thing the red is going to be my choice
im not running stock manfold and i have aem so no maf
Old Feb 17, 2010 | 02:24 PM
  #93
boost_junky2000's Avatar
The red was def. going to be my choice, until the new green came out. Dammit Fp and how come no 4" hardpipe intake for the evo, like the one for the dsm?
Old Feb 17, 2010 | 02:25 PM
  #94
Timmay81's Avatar
im sure they will have one soon enough
Old Feb 17, 2010 | 02:49 PM
  #95
RockmanX's Avatar
what maifold are you running tim?? You need to see my custom one that just got finished. as you stated you went with the top dog like me the fp black. Carlos you do realize the fp red is not to much slower in spool then the green. but i understand if you want in the powerband as fast as possible with decient top end.
Old Feb 17, 2010 | 03:05 PM
  #96
Timmay81's Avatar
i run the SPEC manifold, noting special but it works
Old Feb 17, 2010 | 03:30 PM
  #97
RockmanX's Avatar
wannnnnnnnnnnnnnnnnnnnnnna see MINE
  #98
fromWRXtoEVO's Avatar
Perrin garbage? do a search on the Perrin intake pipe with their filter, it had the biggest gain I ever seen.
Carlos
Old Feb 17, 2010 | 03:31 PM
  #99
Timmay81,
Changing the subject, I ordered a brand new HTA Gren this morning. I will let you know as soon as I get it installed, driven, tested, dynoed and tracked.
Carlos
Old Feb 17, 2010 | 03:43 PM
  #100
Timmay81's Avatar
yea for sure man id love to hear the results, and yes i think perrin isnt that great and very over priced. maybe for a stock evo i guess it would be ok
rockman lets see it
Old Feb 17, 2010 | 03:58 PM
  #101
buchnerj's Avatar
Carlos
The Perrin intake is garbage, IMO. I have seen too many people with gunk in their pipes or the filter just cracking on them from the heat underneath the hood. It does a terrible job in filtering out small particulates from the intake air. Less filtration means more crap makes its way into your turbo and eventually your cylinders.
Old Feb 17, 2010 | 04:31 PM
  #102
Erik@MIL.SPEC's Avatar
Timmay81,
Carlos
Thanks
We should be expecting a 24 psi tune or so on crap 91, correct?
Old Feb 17, 2010 | 06:12 PM
  #103
RockmanX's Avatar
pmed tim. the HTA Green will do its thing for sure. Cant wait to see what kind of monster it becomes in Mikes hands
Old Feb 17, 2010 | 06:50 PM
  #104
Not to call you out or anything like that but do you realize that the 4" FP aluminium cast intake use to have a taper silicone adapter(depending on the turbo).
FP does offer indeed a intake pipe for the FP Red, Green and Black but it is made of silicone. Also the outer diameter is now 80-84mm so 4" would be a 100mm (too big).
I just ordered today a HTA GREEN and I had absolutely no need to get a bigger cover port. There is a lot of literature about bigger port =lesser surging but I know of a tuner that had difficulties already tunning a HTA Green with a bigger port cover and a specific intake pipe causing surging.
Carlos
Old Feb 17, 2010 | 06:57 PM
  #105
Originally Posted by Erik@MIL.SPEC
Thanks
The tune, parts and temp conditions will determine the boost. I got my car tune in August in Phoenix at 4pm at 110 degrees and the car could only boost 23.5psi before developing knock. I am now running 27-28psi peak on 91 oct and absolutely no issues. I haven't decided what injectors I am going to use, I have a set of PTE 680 cc and a set of FIC 1050 cc but I might end buying something else.
Why the 24psi on 91oct quote/remark though?
Carlos
