Fp Black vs HTA 3582
How can you possibly stand behind a turbo when you havent even installed it yet?? Im starting to think you work in FPs marketing department.
you dont see it cause fp is a great company and replaces them...so why would a customer say anything??
i have 2 buddies who have both been through 2 plus reds and are now on ball bearing turbos..with tubular manifolds now.
they got sick of the down time...
i have had a 30r ...now a hta 3582 and beat the **** out of them never blew a turbo
if you are going to run mild boost under 25 lbs sure a stock frame turbo is great.
but if you want to run higher boost they dont last.
how long is a long time?
i think another issue is there is a diff color and model green...new green...red...this mm red..black...
you either sell your old and buy a new or send it in for and upgrade...
i know when they do blow no one posts cause they get another one..happened to a few people i know they didnt want to bash the turbo or the company.
but they went after a few months..granted these guys are track ****** but still..
you pay that kind of money for a turbo you want it to last.
I stay off the forums for a couple days and you jump on the black band wagon
Hehehe... Good Luck! If you need anything let us know! Make sure you post up results.
Thanks!
Michael
Hehehe... Good Luck! If you need anything let us know! Make sure you post up results. Thanks!
Michael
Just bought a tubular for my red and magnus v5 intake manifold, ported throttle body, o2 dump, speed density setup and some other mods. I should be able to make 530+whp easy on pump gas with the fp red at like 29 psi on a dyno dynamics with a 1.2 correction factor. Last time i was on the dyno I made 480+ at 29 psi 1.2 correction factor, without the magnus intake manifold, ported throttle body, tubular exhaust manifold,speed density setup, and 3 port boost solenoid.
. i have several friends on here that run it and run there cars with no issues period i have talked to robert about my situation personally when i had the red to upgrade to the black and he spent some time on the phone breaking things down. Did not have to do that with his time. There are failures as nothing is perfect. but they honor them and replace them and nuff said people are stupid to think 35r type turbos etc dont fail nothing is perfect but fp turbos DO WHAT THEY ARE SUPPOSE TO DO produce power and results. parts breaking are a part of the game
My red seems to be working fine. 508whp on 31-32lbs measured by defi boost gauge. when i put on the 4 bar map sensor i think im really pushing around 30lbs. well see if i can add a few pounds soon.
FP failure poll here: https://www.evolutionm.net/forums/ev...bo-failed.html
I am interested to see the numbers
my HTA gt3582 with the 1.06 ar t4 twin scrool housing hits 200whp by about 4k rpm on the stock motor with HKS 272's. 20psi by 4k rpm in 3rd gear. Hows does this compare to the new FP black?
Epic motorsport did 443 hp & 417 tq on pump gas w/ the fp black at 25 psi. The torque on this turbo is amazing.
