ACD Tuning Options - USDM CT9As, Read!
Old Oct 6, 2014 | 09:32 AM
  #376
JohnBradley's Avatar
Thanks for the review Kyoo
Old Oct 6, 2014 | 09:44 AM
  #377
SWOLN's Avatar
I guess that's another thing I'll be getting from ER.
Old Oct 6, 2014 | 10:29 AM
  #378
golgo13's Avatar
EvoM Community Team
Veteran: Navy
Originally Posted by kyoo
The only issue I've had come up is that the 3lights will turn on every once in a while when I'm sitting idling, which go away if I restart the car. No impact on driving or while I'm moving, and hasn't been a factor for me.
Try bleeding your ACD pump. I had bubbles in mine and that cleared up the issue I was having at the track with the pump going into limp mode.
Old Oct 15, 2014 | 02:57 AM
  #379
tscompusa's Avatar
Doing a special for the 6 map program we offer. Only $216 shipped right now and also willing to do a second custom flash based on feedback after the end user verifies whether or not he or her is happy with the performance or not.
For now its just 3 custom maps with 3 stock maps. So the vehicle will still be able to function in stock form if need be.
There is several time attack cars running these maps and placed 1st place multiple times now.
I am confident these maps will better your track times and performance in general if you're still running the stock maps.
I have built a cable now to flash instantly, so turn around time is instant.
Picture of flashing Keith's ECU:
Old Nov 10, 2014 | 05:15 PM
  #380
kaj's Avatar
kaj
i'm assuming tuning ideas for this are being kept secret as opposed to other EcuFlash information? or is it more involved than just hooking up the Tactrix cable and reflashing?
Old Apr 26, 2015 | 09:39 AM
  #381
I_want_MR's Avatar
Must do!
Old Jun 24, 2015 | 08:13 AM
  #382
kyoo's Avatar
been a long time without updates - anyone doing this for the 2015 season?
Old Jun 25, 2015 | 12:21 PM
  #383
Shiroi Kitsune's Avatar
Well I've had the ER tune for awhile now so I feel I can confidently give a good review on it. I have the 3 map like kyoo, however I believe the snow mode is a little more aggressive than the stock Tarmac mode.
Just for reference, I only do road course, no auto cross, and have been running stock size RS3 version 2s the entire time. Power is at about 330hp 330tq to the wheels.
Initially I was on stock suspension with a restacked stock diff. On the street the difference was night and day. Every mode made a massive difference and cornering was dramatically improved. Just dial in the oversteer you'd like. On the track the difference was not so dramatic. The car was a little more balanced but switching modes didn't seem to change much.
Fast forward a little bit and I'm running ohlins, whiteline pretty much everything, Perrin psrs with castor offset and whiteline rsb. I've now gained the same effect on the track that I initially had on the street. Just dial in the rotation with a button on the dash. I set it low on open sweeping sections and bump it up for the tighter areas where I need a little more rotation. I couldn't be happier.
In addition English Racing was awesome to deal with and really takes customer service seriously. They will be hearing from me again when it comes to beefing up the power.
Old Jun 25, 2015 | 12:50 PM
  #384
kyoo's Avatar
great review! similar suspension setup but not all the bells and whistles, very happy with how my car behaves
Old Jun 25, 2015 | 12:53 PM
  #385
wjamyers's Avatar
I guess this is the "last" thing I want to do to mine...
Old Jun 25, 2015 | 02:31 PM
  #386
Raptord's Avatar
Suuuuuuuuuuuuuure it is...
Old Jun 25, 2015 | 06:53 PM
  #387
I forgot to mention I also have the problem with all the lights coming on after idling long term. My acd has been bled several times since and it did not cure the issue. No big deal through. I'm not idling when it matters and a quick flick of the key fixes it.
Old Jun 25, 2015 | 08:35 PM
  #388
kaj's Avatar
kaj
did you check the fluid level in the reservoir when this happened? i once forgot to top my fluid off after the last round of bleeding and had the same thing happen LOL.
my fluid level differs when running compared to not, if i remember right.
Old Jun 26, 2015 | 06:37 AM
  #389
wjamyers's Avatar
seriously!
Old Jun 26, 2015 | 08:46 AM
  #390
Yeah it's full. I've even moved it to the trunk since so it's been bled plenty.
