GSC S2 cams who is using stock springs?
Old Feb 20, 2010 | 07:43 AM
MR:PartyPete's Avatar
So just the springs? Everything else is up to the task of 8k rev limit?
Old Aug 26, 2010 | 07:33 PM
4G63 T's Avatar
bump
Old Aug 26, 2010 | 07:40 PM
AWD Motorsports's Avatar
We have them on probably 20 cars without an issue.. However these are stock turbo cars.. I would not run stock springs on FP turbos or larger as they will float.. Stock Turbo 400-420hp cars we have atleast 20 of them running around without an issue.. The RPM doesnt change anything the valve float most times at Peak TQ not on top.. On top they catch back up..
Mike
Old Aug 26, 2010 | 07:45 PM
4doorstreetbike's Avatar
Originally Posted by AWD Motorsports
We have them on probably 20 cars without an issue.. However these are stock turbo cars.. I would not run stock springs on FP turbos or larger as they will float.. Stock Turbo 400-450hp cars we have atleast 20 of them running around without an issue.. The RPM doesnt change anything the valve float most times at Peak TQ not on top.. On top they catch back up..
Mike
How do you know when your getting valve float??I know lots of people running them with big turbos revving it to 7,800 rpms with no ill effects.
Old Aug 26, 2010 | 07:49 PM
Like i said RPM has NOTHING DO WITH IT.. I have NEVER seen a car float on top if it didnt float down low at PEAK BOOST.. Boost is the cause.. You can have no float at 27psi and 30 psi immediate float.. You know from experience when you see it on the dyno chart.. The power dips..
Mike
Old Aug 26, 2010 | 07:53 PM
Here is an example of 1 with no springs retainers running for months and months on 450hp with red.. Thing is he is on Pump Gas.. If it was E85 ill guarantee it float probably.. We gave it a shot without and never had an issue.. I have recently come across an E85 Red car with S2s that we did that as floating and could not control it without lowering boost and then adding GSC beehive.. Fixed..
https://www.evolutionm.net/forums/ev...93-octane.html
Old Aug 26, 2010 | 07:54 PM
Mike
does this graph look like it's floating??thanks.
https://www.evolutionm.net/forums/ev...ce-6262-a.html
Old Aug 26, 2010 | 07:55 PM
There is no dip in power is there?? then it isnt..
Old Aug 26, 2010 | 08:16 PM
4G63 T's Avatar
i have 2.3 with 35r,,stock IM...wanting step up to S2
Old Aug 26, 2010 | 08:20 PM
LOL thanks mike..
Old Aug 26, 2010 | 09:29 PM
sho669's Avatar
I never really even thought about higher boost causing valve float...too much time building N/A Chevy's I guess. It does make sense though, learn something everyday, thanks Mike!
Old Aug 26, 2010 | 09:34 PM
Your Welcome..
Old Aug 27, 2010 | 08:40 AM
rovanpera's Avatar
can you elaborate on the max torque causing float? it makes no sense to me, i understood float as the inability of the valve to follow the cam profile purely diue to inertial reasons, hence the higher the rmp the higher the chance of float....
Old Aug 27, 2010 | 09:37 AM
Peak boost hits right around where TQ is.. That hard hit when the boost ramps in is where the valves usually float from my experience.. It can be 500 rpm after Peak TQ or so but from every case i have seen floating valves it starts long before high rpm.. As soon as you drop boost a few psi the valve springs hold..
Mike
Old Aug 27, 2010 | 10:16 AM
ezz-e's Avatar
That some good info there mike thanks for sharing
weeeeeeeeee
Nov 8, 2016 12:36 PM
06GraphiteEvoIX
10
Sep 2, 2010 03:57 AM
whitepwr
Jul 21, 2010 02:53 PM
hawaiian_evo
Apr 8, 2009 01:32 PM
EvoDom
Dec 17, 2008 02:02 PM
