How much HP from Porting FP Red
Old Mar 3, 2010 | 09:53 PM
  #211
CO_VR4's Avatar
Originally Posted by BLKCarbonEVO
I would def go SD. I don't know that it is really worth much hp but the drivability is tremendously increased
No the spring is the same as the Tial I believe. It has two springs in it. It is not suppose to flutter because the lighter spring is for low boost just driving around town and the second heavier spring in for high boost. So ya there are two springs inside. One inside of another. I didn't take it apart but I'm pretty sure that is what Turbosmart told me
Mikey
With the Tial the two springs work together to increase the total spring pressure. There is no switch between high and low boost, unless you take out a spring or change the springs themselves...
If you have two springs in your BOV, pray tell how one only works during "low" boost and the other during "high" boost. What dictates which one is controlling boost at any given time?
Old Mar 3, 2010 | 10:13 PM
  #212
CO_VR4's Avatar
Originally Posted by sparky
Mikey: I have spent about 5 hours searching old EvoM threads trying to find Tom's pics of his ported turbine inlet area, however I have not been able to find those pics, Sorry, buddy!
Here's a place to start
https://www.evolutionm.net/forums/5747822-post968.html
Old Mar 3, 2010 | 10:33 PM
  #213
BLKCarbonEVO's Avatar
^ all I know is what turbosmart told me. They said because of their two spring design I wouldn't have low boost flutter, that's why I went with them and not Tial. I never took the bov apart so I'm not sure if the Raceport is the exact same as the Tial.
  #214
Originally Posted by JohnBradley
I have them, but unfortunately they are on my computer at my brothers...wont be till this weekend.
aaron
That would be awesome Aaron if you can pass those our way
Mikey
Old Mar 4, 2010 | 08:45 PM
  #215
sparky's Avatar
*edit*
Old Mar 11, 2010 | 09:19 PM
  #216
iTune's Avatar
Bump.....what was the final outcome?
Old Mar 11, 2010 | 09:27 PM
  #217
boostedtres's Avatar
i would like to see results along with more info on the dual race port Turbosmart BOV. i have the normal turbosmart, and it works great, barely any flutter and holds boost like a Bi!ch
Old Mar 11, 2010 | 10:16 PM
  #218
The RacePort is an amazing BOV and I love it. It is a direct replica of the Tial 50mm. I honestly like it more though. There is not a lot of info on the web about it I have nothing bad to say at all. It def doesn't leak boost at all
Hey guys, sorry for not keeping you informed on the progress. We ran into a bit of a delay with some of the custom parts we had to order We were hoping to have everything ready to dyno this weekend but that won't happen.
Tuesday my car goes to ER for my LR2.4 build and we will be doing the before and after of the two housings on the 2.4 rather than the 2.0. Figure the gains would be even better on a 10:1 LR2.4 w/ 288 cams and 40+psi than the stock motor on 30psi. Things should be really interesting.
Looks like the car will be broke in and on the rolls sometime in the middle of April. I will keep everyone updated I can't wait to see the results but I think waiting till the motor build is done will net us the most gains anyway. I think a 25hp gain on a direct swap with be easy!
Mikey
Old Mar 14, 2010 | 08:43 PM
  #219
JohnBradley's Avatar
Mikey
These are the only ones I have, no inlet pictures.
Old Mar 14, 2010 | 09:26 PM
  #220
pheonix991's Avatar
Curious, very curious...
Old Mar 14, 2010 | 11:58 PM
  #221
Aaron that looks great. I'm sure Eric will have some dope pictures soon... Not sure when we are going to release the design. Prob after the before and after dyno... Or we may just keep it a mystery.
Mikey
DSMolition
Aug 10, 2017 12:29 AM
211Ratsbud
Oct 28, 2016 07:47 AM
balls_deep_evo
Jul 26, 2016 01:02 PM
EndlessRed
Evo X Dyno Results
10
Feb 4, 2013 04:58 PM
sege968
Jul 16, 2010 07:24 PM
