Help... how do u remove and replace the fuel tank
Old Mar 15, 2010 | 01:09 PM
lilevo1's Avatar
I need help..
i hit something at night and it put a crack in my fuel tank.and efed up my exhaust..
so i need to know how to remove the tank.. is it hard?
YES IVE SEARCHED AND NOTHING..
thanks
Old Mar 15, 2010 | 04:07 PM
lilevo1's Avatar
Bump
Old Mar 15, 2010 | 04:37 PM
Funkster's Avatar
Never done it on an Evo but for most cars it is pretty straight forward.
Drain fuel from tank
Disconnect fuel lines
Remove straps holding tank in place
Remove tank
Obviously there may be a few clips and things to remove that are not on that short list, but take your time and you will be fine. It is a pretty standard procedure.
Old Mar 15, 2010 | 07:20 PM
barneyb's Avatar
You have to remove the differential support member and drop the front of the differential. Then the tank comes out towards the front. This, after unhooking a bunch of stuff.
Old Mar 15, 2010 | 07:32 PM
lilevo1's Avatar
how difficult is it to remove that
Old Mar 15, 2010 | 07:45 PM
sktng22's Avatar
o god removing a fuel tank probly sucks to do on our cars...
Old Jul 2, 2012 | 04:04 PM
okevolutionVIII's Avatar
Sorry to bump an old thread but I'm in a situation where I need to drop the tank and clean it as rust has come back to haunt me after filling the tank for the 1st time in 4 years.
Is there anyone who has some decent details on what needs to be unhooked/unbolted to get it out?
Old Jul 2, 2012 | 04:19 PM
mt057's Avatar
How's this?
Old Jul 2, 2012 | 04:22 PM
I'm scared now....
Old Jul 2, 2012 | 04:28 PM
mt057's Avatar
Lol. It looks to mainly be a bunch of hose/wire connections. There should not be too many bolts. I have not attempted this though...
It sounds like you are getting closer to getting her running. Let me know if there is anything I can do to help (short of doing anything...J/K).
Old Jul 2, 2012 | 04:45 PM
I've put about 130 miles on it in the last week and it's making good power but when I filled up the tank the other day, it immediately started running rough so I pulled the pump and found light brown gas....again.
Old May 24, 2022 | 06:16 AM
monkey.penllwyn's Avatar
Tank
Found this thread and didnt get the answer i wanted so thought id just put that u can get to the **** ontop of tank even the crossover joints if u just drop the tank bolts n let it sit on the prop etc
Old Jul 14, 2022 | 08:32 AM
Evo2372's Avatar
Pretty sure it's a pita
search Devin's YouTube channel as he does it on the blue Evo 8
Wasn't fun if I recall correctly
Good luck
Old Jul 16, 2022 | 08:22 AM
Smoknzx3's Avatar
Did you get it removed. Took mine off. Wasn’t to bad. Let me know.
GeorgeP
Northeast Region
May 18, 2017 07:12 PM
Tw3NTy0n3
Feb 17, 2017 08:57 PM
Masterr
Dec 13, 2016 04:52 PM
impact blue
Mar 18, 2016 09:54 AM
TURBO_S2K
Jul 1, 2013 06:49 PM
