Intake Cam angle position sensor help
Are the cam angle position sensors the same, and interchangeable between intake and exhaust? Between VIII's and IX's?
Can anyone confirm if MD327107 is the intake cam angle position sensor for a IX?
I recently found that my intake cam angle position sensor was cracked, I bought a used one thinking it was interchangeable and I still have a CEL. I can reset it, and drive one time, shut the car off and it will come back on the next start.
I searched here and another forum, but couldn't find an answer. Appreciate any help I can get.
No I didn't reseal it. And yeah once you have that plate off the trigger wheel is either laying there or attached to the cam as it should be. The intake one you cannot put on wrong either, the exhaust cam however will go on correctly or 180 degrees off
Thanks, I know that, I just wanted to know if the sensor would work in either position and if you could use an 8's exhaust sensor in a 9's intake position.
Back from the dead.
There are two different sensors for the IX, one has a painted dot (Exhaust) and the other does not (Intake). MD327107 is the exhaust but can not find a p/n for the intake. Dealer won't give out this info. knowing you'll purchase from another source and the Parts List on this site only has one number.
asu11
Apr 25, 2016 11:52 AM
Graphic
10
Oct 24, 2011 10:37 AM
