evo ix drain plug stripped oil pan question
Old Apr 5, 2010 | 02:11 PM
20gmr's Avatar
Its Shellac, IDK but it works. I would read the bottle but it tends to drip over the edge and dries like a resin so i can't make it out lol. You have to give it plenty of time to setup is the only thing, I guess it would be similar to liquid Teflon but dries harder.
Old Apr 5, 2010 | 03:24 PM
Tagge's Avatar
kk awesome guys thanks so much for everyones help
Old Dec 1, 2010 | 12:43 PM
yuhou411's Avatar
I ran into the same exact problem a couple days ago and have been going to diff shops to see if they can take it off.... And they can't. So I need to replace my oil pan too so I was wondering what you ended up doing
Old Dec 1, 2010 | 02:19 PM
yuhou411's Avatar
Also do you need to replace return tube and gasket? How difficult is the job?
Old Dec 3, 2010 | 03:03 PM
Tagge's Avatar
I replaced the gasket it was like two bucks and used Indian head gasket on it. Job wasn't to bad gotta move starte FYI
Old Dec 3, 2010 | 06:37 PM
Xenogenic's Avatar
you have to remove the starter, dp, and cross bars. then just the how many ever 12 or so pan bolts. the pan is RTV'd on. i've used Hondabond and generic autozone rtv and both work aslong as its gray. make sure you don't bend the pan removing it depending on the previous RTV job it could be sealed up pretty good.
Old Dec 3, 2010 | 06:38 PM
Xenogenic's Avatar
also it'd be a good idea to get a new gasket for the return line
Old Dec 3, 2010 | 07:03 PM
sparky's Avatar
Originally Posted by Tagge
Lol haha guess it's really that common hear the Mitsubishi silicone isrhe only one I should use. Cause I work at Nissan and Honda and the hondabond is really good but i guess I should just use the Mitsubishi brand?
I personally wouldn't hesitate to use the Hondabond HT in this particular application.
Verlassene
Mar 9, 2017 11:04 AM
nrt5pitt
Feb 5, 2011 04:31 PM
Compjoc
Apr 8, 2005 05:50 AM
EvilBlueEvo8
May 30, 2004 08:41 PM
nostim
Feb 19, 2004 02:49 PM
