Compression Test today 100/120/117/118
Old May 19, 2010 | 05:34 AM
  #46
GG06MR's Avatar
Originally Posted by Wht03evo8
Ok, i finally got ecuflash working on my Mac, so which numbers do i need to be looking at i am a Complete NEWB when it comes to tuning a car and being able to read these numbers. So anything you want to know i will tell ya. Air Fuel looks like it was 14.7
Not throughout the entire powerband right?! You'd have way more than 7 counts of knock with a 14.7:1 AFR on 91 octane.
Old May 19, 2010 | 05:45 AM
  #47
Raptord's Avatar
You'll need to read the stickies in the EcuFlash section if you haven't already done so before you start messing around with your map. This is a good place to start :
https://www.evolutionm.net/forums/ec...-tune-evo.html
Old May 19, 2010 | 08:06 AM
  #48
Bignel00's Avatar
Originally Posted by Enzo1089
Ugh
So what are the major draw backs of having low compression, besides needing a motor overhaul...
I'm trying to stay positive and think that having my compression messed up is robbing my power so the car will be faster when its fixed This is correct right?
car will be faster. How does the car run now ( with these compression numbers ?)
Old May 19, 2010 | 09:11 AM
  #49
Enzo1089's Avatar
The odd thing is, it runs great. I beat Vipers and GT500's at the drags and I'm still on the stock 8 turbo with 91 octane.
Old May 19, 2010 | 01:48 PM
  #50
MOREPSiTEHBETT4's Avatar
you are drag racing and you are knocking to crap...a responsible owner would park the car and take it to gst and get it tuned by brian..done
don't drag race the car, I wouldn't even drive the car if I had 7 counts of knock and didn't know my afr
Old May 19, 2010 | 02:41 PM
  #51
Wht03evo8's Avatar
LOL, he is not the one with the F***ed up counts of knock! that would be ME and the car just sits in the garage waiting to be touched.!
The AFR at 1000RPM to 5500RPM at 80% load is at 14.7!
There is NO way that i am gonna attempt to mess around with the map I am not gonna risk blowing the motor just the hell of it. I am trying to get some type of solution to the issue prior to going to GST.. i dont want to drive 1.5 hours to get told "I am sorry i cant Tune your car cuz of ......"
Old May 19, 2010 | 03:50 PM
  #52
Raptord's Avatar
It's normal for the car to be at or around 14.7 AFR when out of boost/at low load. By 80% load do you mean actual load or TPS? If it's load then I think it should be at least a bit richer than that over 4-5 grand, but I'm just guessing here, don't take my word for it.
EDIT: Also, are you looking at AFRMAP in your log file, or the real AFR from a wideband?
Old May 19, 2010 | 04:33 PM
  #53
Wht03evo8's Avatar
I am looking at the Log, i do not have my wideband installed yet
Old May 19, 2010 | 04:43 PM
  #54
Ludikraut's Avatar
At 80% TPS it better be at significantly less than 14.7 AFR when the turbo begins spooling up.
Wht03evo8, take your time. Read some of the how-to posts in the ECU flash forum ... as a matter of fact read them once, then read them again until you can almost recite them in your sleep. If you're going to attempt to tune your car, it's well worth the extra caution and time. If you haven't already done so, also invest in a wideband and make sure it's installed and calibrated correct. Once you get into it, you'll probably find that tuning isn't all that hard, but it is time-consuming.
l8r)
Old May 19, 2010 | 04:50 PM
  #55
Wht03evo8's Avatar
I have an AEM wideband already i just have to get installed, and to be really honest with you and everyone i have no interest in tuning my own car.
Old May 19, 2010 | 04:51 PM
  #56
dcamp56's Avatar
i heard that as long as the compressions are all close to each other you are fine
Old May 19, 2010 | 06:25 PM
  #57
Raptord's Avatar
If your wideband isn't installed then where did you get 14.7 from? AFR MAP?
dtenev2
15
Nov 4, 2017 12:11 AM
Drill_Sergeant
May 26, 2014 12:59 PM
Colbyy
28
Jul 19, 2011 06:38 PM
Stradag
Apr 26, 2010 03:49 PM
FathouseFab
May 7, 2008 09:24 AM
