smokin evo 8
Old May 27, 2010 | 08:13 PM
Billy05MR's Avatar
smokin evo 8
Hey guys. I just got into DSM and i dont know much yet. My car smokes very badly after I stay in high boost for longer than a couple seconds. And i keep blowing my blow off valve off my up pipe. The reason for that is the pipe gets very oily and it looses grip. What seal needs replacing and where can i get it?
Old May 27, 2010 | 08:20 PM
vanilla2's Avatar
How long have you had the car? What mods? How many miles does she have?
jmelocik's Avatar
An Evo is NOT a DSM. Most likely your valve cover vent is still routed into your MAF pipe which goes into the turbo. The oil vapor goes through the turbo and coats the inner cooler piping as it cools off and gets on the inside of the FMIC and UICP and can cause the coupler at the throttle body to become oil soaked and swell and blow off. Sometimes other couplers can do the same things.
Josh
Old May 27, 2010 | 08:22 PM
sparky's Avatar
You have to try to be more specific and descriptive. For example, does it blow white smoke when you let off the throttle after being on boost? It could be piston rings, valve seals, valve guides, or the turbocharger´s seals, among other things.
EDIT...How much boost are you running? Is you car using oil?
Old May 27, 2010 | 08:23 PM
Bom's Evo's Avatar
Might be your valve seals...Are your spark plugs oily too?
Old May 27, 2010 | 08:25 PM
Billy05MR's Avatar
Yeah its when i let off but only if it is a long pull. I've had it a month now. It has 61,000miles on it. Intake, upper and lower Intercooler pipes, turbo back exhaust.
Old May 27, 2010 | 08:32 PM
sparky's Avatar
White smoke when you let off after a pull is most likely turbocharger seals. Send your turbo into FP, or Blouch. Or a local turboshop that does MHI turbos. Dark smoke is something else.
Old May 28, 2010 | 08:11 AM
turbolarry's Avatar
Is the hose clamp on there and are you tightening it with a socket/ratchet?
soon2bEVOIX
19
Oct 7, 2017 12:03 PM
gullie667
23
Mar 17, 2009 08:10 AM
UntouchableEvo
14
Oct 29, 2008 01:47 PM
whitersevo
Jan 27, 2007 04:31 PM
o6RSEvo
Jul 16, 2006 12:32 PM
