Uicp/licp
Uicp/licp
My last thread was closed and I did not have a chance to check my computer for replies...so I am starting a new one.
Once again if I was to swap out the stock pipes for some after market ones, which ones do you guys suggest and do any of them come with a blow off valve?
Also is it worth putting on a blow off valve to get the whoosh sound and are there any gains/losses with it?
Your Post
Just change the LICP, the UICP is fine unless your running like 30psi of boost. No reason to change the upper one, the HP gains are nil unless your running a big turbo with lots of boost. the LICP is a must. My ten cents....
I'd disagree with the above...the lower would be my last swap if you had to choose 1-opt for the AMS or bushcur set up imho, I had the buscur and loved them, a guy here in MN has an AMS set up and has been doing great (gates, cough cough
the upper has more room to "swell" under full boost then the lower/cold pipe. Cobb has a pretty decent set up that looks good too-if you go with a full cobb set up, you can invest in a AP and have a pretty good Daily driver on the roads!
).the upper has more room to "swell" under full boost then the lower/cold pipe. Cobb has a pretty decent set up that looks good too-if you go with a full cobb set up, you can invest in a AP and have a pretty good Daily driver on the roads!
Are you talking about the 4G63 or the 4B11??
You can't go wrong with any of the UICP offerings on the market. I have AMS and they are great, I highly recommend them. LICP isn't necessary, as zero to minimum gains are seen when adding it.
You don't really need a BOV either - once you get an intake (I recommend the AMS intake), you will hear that nice whoosh you are looking for.
Man that is completely the wrong way around for the X.
I went to the local tuning shop and talked to them about a blow off valve, the guy there said it might actually be a negative and reduce engine power... has anyone had any luck with an after market blow off valve?
No need for a BOV
We have plenty of kits in polished and black in stock. Also, our lower IC pipe is completely 3" for reduced pressure drop.
http://www.agpturbo.com/product.php?...cat=325&page=1
TxFAkuma
Nov 27, 2016 01:52 PM
Zlord8
10
Jul 24, 2009 02:00 PM
