What should my EGT Gauge be reading?
Old Nov 17, 2003 | 01:40 PM
tlin8's Avatar
I've been kind of worried lately because my EGT's been going up to 90-95. I never floor my car, but when I'm going around 65mph and gas it a bit making it goto 80-85mph, the EGT hits around 90-95.
A friend of mine with a WRX says that its NOT normal. I was just wondering what you guys with EGT gauges think.
My EGT Probe is in the Exhaust Manifold and not the downpipe.
I have a S-AFC II (which might be causing the problem...the shop I went to set the settings. They said that the settings were for the EVO VII so I just let them do it.)
Old Nov 17, 2003 | 02:43 PM
Fireball's Avatar
Moving this to Engine/Turbo/Tranny... probably get some more responses..
Old Nov 17, 2003 | 06:36 PM
Boost Solutions's Avatar
So you are saying 90-95, that does not sound normal, I quess is time for upgraded intercooler , just kidding. If the S-AFC is using the settings for the Evo7, that might be the problem. Check if you can find the settings for the Evo8.
Andy
Old Nov 17, 2003 | 08:15 PM
tlin8's Avatar
Andy
Thats what I probably will do. I was also thinking about doing a dyno tune when one of the shops come down to So Cal.
Old Nov 17, 2003 | 09:09 PM
Coolguy949's Avatar
Where is your EGT probe located?
Old Nov 18, 2003 | 07:08 AM
EvoJimbo's Avatar
Old Nov 20, 2003 | 01:04 AM
bpclements's Avatar
Are those numbers 900 to 950 degrees Fahrenheit or Celcius? Also, what is the average that you should expect to read? I am getting an EGT in soon and an AFC 2.
Thanks
Old Nov 20, 2003 | 01:07 AM
Coolguy949's Avatar
EGT is in Centigrade
Old Nov 20, 2003 | 04:50 AM
xtnct's Avatar
EGT Probe location: exhaust manifold top of runner 1 about 5cm or so from the head.
Gauge & Probe: Autometer measuring in F. max @ 1600F
Car: stock
Readings: idle is about 900-1000F, cruising in gear is in the 1200F range and if I WOT I get into the 14000F.
EvoTurboTurk
10
Jul 19, 2013 05:22 AM
IceHawk
For Sale - Wheels / Tires
Jul 4, 2009 07:53 PM
lightspeed1
17
May 2, 2009 12:25 AM
wj4
Oct 24, 2006 08:23 PM
NRG
Aug 17, 2004 08:23 PM
