springs and retainers??
Old Jul 4, 2010 | 09:29 PM
vmrevo9's Avatar
Veteran: Air Force
i know it is recommended but is it necessary to change the retainers as well. i am planning on going with GSC S2 and a BBK full or B turbo and i want to upgrade the springs. i am looking in to the GSC springs or supertech.
another question i have is do i need to go with dual springs or will the single springs (beehive) be enough? what about the retainers? i do not plan on going over 8 to 8.5K rpm if that only at the drag strip. i never really see anything past 7K in the street anyway.
thanks guys
Old Jul 4, 2010 | 09:36 PM
evoforlife's Avatar
i did the single beehive GSC with stock retainers on my gsc s2 cams, which are good up to 9k rpms or a little bit more and are only $220 hope this helps
Old Jul 4, 2010 | 10:57 PM
vmrevo9's Avatar
Veteran: Air Force
those are the same ones i'm currently looking at. i know that adding the titanium retainers reduces weight but is it needed and is the difference noticed? i do not plan to get the head ported yet i plan on saving that for much later. i would think that the single beehave springs should be enough but i want to hear from the community and see what the experience and opinions are.
on which car are you currently runnig that setup on? and how much do you usually rev to?
Old Jul 4, 2010 | 11:46 PM
RSMike's Avatar
are the stock evo9 retainers titanium or alloy? they are super light from stock anyways.
Old Jul 5, 2010 | 02:06 AM
iEvoIX's Avatar
GSC S2 are pretty good.
Old Jul 5, 2010 | 02:43 AM
vmrevo9's Avatar
Veteran: Air Force
no i think they are about 14 grams or so. i read that titanium is about 7-8 grams. do not know the material of the stockers
Old Jul 5, 2010 | 04:26 AM
Mellon Racing's Avatar
hey Vic, Kevin did beehive springs only with his 9, let us know if you need anything, we carry everything you're looking for
Old Jul 5, 2010 | 07:11 AM
bbyevo8u's Avatar
+1 they are super light with a really good design
im running the oem retainer with upgraded beehive springs revving to 8k
John
Old Jul 5, 2010 | 09:46 AM
vmrevo9's Avatar
Veteran: Air Force
hey Chris,
i was looking at your site the other day and i am very impressed with how much it has grown!! i'll send you a pm. right now i'm looking for 1000cc injectors and springs.
thanks
Old Jul 5, 2010 | 09:56 AM
Babs's Avatar
The stock retainers are aluminium I believe...And I would replace the retainers with the springs. Usually when you buy springs, they'll come with retainers unless otherwise noted.
Old Jul 5, 2010 | 10:09 AM
lillev23's Avatar
I have the Supertech springs and retainers in mine. I know these work well past 8k. Never had any problem woth valve floaet or anything like that.
Old Jul 6, 2010 | 06:13 AM
springs and injectors
pm'd
Old Jul 6, 2010 | 09:34 AM
vmrevo9's Avatar
Veteran: Air Force
pm'd you back!
ayoi
29
Dec 4, 2018 06:17 PM
evoniners
May 16, 2016 06:04 AM
riceball777
15
Jun 18, 2012 11:02 AM
sLowEvX
May 4, 2012 05:46 AM
AKgambler47
Mar 14, 2008 04:24 PM
