View Poll Results: Have you gotten a CEL with the pipe, or not??
YES,.........CEL came on.
9.09%
No, Havent seen one at all.
20
90.91%
Voters: 22. You may not vote on this poll
UR 3" test pipe...NO CEL??
Old Nov 19, 2003 | 11:39 AM
mitsuorder's Avatar
there are 4 wires, 1 blue, 1 white, 2 blacks, do not get the 2 black wires mixed up. Cut one at a time and solder in a the provided extensions, remember too long is much better than too short. I picked up a butane powered soldering iron from Radio Shack to make the job easier, I suggest using heat shrink to ensure that the connections are protected from the elements.
Old Nov 19, 2003 | 11:56 AM
PocketAces's Avatar
Hey 93Civic--
Do you already have a downpipe and catback or are you adding this to the stock configurations. If you are adding to the stock configurations, might I recommend going with the 2.5" instead of the 3"? It will actually cause you to lose some HP or give you very minimal gains if the exhaust is going from restricted to open to restricted again.
Just a tip--take it for what it is worth.
Old Nov 19, 2003 | 12:40 PM
C-Murdock's Avatar
hmm man that sounds like a pita
Old Nov 19, 2003 | 03:08 PM
evil8's Avatar
Anyone know if you can remove the o2 sensor part out of the car? It would be much easier to do the soldering with it on a table than crawling under the car to do it.
Old Nov 19, 2003 | 05:27 PM
93civEJ1's Avatar
no...i will be joining it with an HKS catback when i get it...thanks though for the heads up.
Old Nov 19, 2003 | 05:31 PM
Jinu0808's Avatar
I have used UR 2.5 and 3.0 test pipe I never solder any wires.
All you have to do is pull out that Donut on the O2 sensor and you will have more than enough to hook it up to the test pipe.
Old Nov 19, 2003 | 05:33 PM
Jinu0808's Avatar
After u pull out the wire make sure you tape up the o2 sesnsor
connector with eletrical tape so this way water wont get in.
And then go to any autoparts store and buy your self another rubber donut to fit on the bottom of the car.
Old Nov 19, 2003 | 07:02 PM
93civEJ1's Avatar
man....sounds like more work than its worth??? i thought it was just plug n play??
Old Nov 19, 2003 | 08:56 PM
evoego's Avatar
Registered User
man its not much work you just have to wire the extra length to fool the sensor.in and out in less than 30 min. get it its the best around.good quality and no CEL for sure.
Old Nov 20, 2003 | 02:32 AM
Compjoc's Avatar
If the O2 sensor is moved to the test pipe to somehow stop a CEL light, what happens to the O2 bung in the cat-back? is there a plug for it or something?
Old Nov 20, 2003 | 10:40 AM
Jinu0808's Avatar
Yes there is a O2 Bung Plug
Old Nov 20, 2003 | 03:44 PM
Compjoc's Avatar
aw sweet, im gonna have to get one of those.
Old Nov 20, 2003 | 03:50 PM
reeLz's Avatar
sorry but it was too tempting to pass up...
"must get plug for my bung hole!"
good ol' beavis.
Old Dec 5, 2003 | 07:45 AM
turboDan's Avatar
no cel,and if you have access to any equiptment to check what o2
sensor is reading,you will see that the sensor stays around .75volts,as to trick the computer that the cat is indeed working and quite efficently at that,but does infact change voltage readings,just slightly,but enough to see that the o2 sensor is indeed working.test pipe works as described,no cel. also,if you remove pass side seat and lift carpeting,you can either unplug o2 sensor to solder on bench in front of you,or you can remove body plug about 8" in front of one that the o2 sensor goes through presently and drop through that one,with no need to cut wires at all,just up to you.remember,you will loose a few psi of boost when removing the cat!!!!!!!!
Old Dec 17, 2003 | 06:36 AM
93civEJ1's Avatar
yes, but when you remove the cat, wont you be making the same amount of power but with less boost?? also for those who have installed.....if you take the rubber housing off the underside of the car that the o2 sensor wire run through, can you not pull it out far enough to reach the test pipe then??? Also, can some people post pics up of their UR pipes installed I would like to see all this after finish.
evonewb29
Sep 21, 2011 07:27 AM
taylorgang
Jun 6, 2011 06:55 PM
drifthobo
Apr 4, 2010 04:58 PM
premo
Jan 22, 2008 12:27 AM
EVIL_EVO_VIII
30
Sep 23, 2005 10:34 AM
