500whp on E85
Old Jul 13, 2010 | 08:34 PM
nikg's Avatar
500whp on E85
How big an injector will i need for 500whp on E85? I am running a pt6262 and I currently have 1000's could the 1000's maybe be enough for 500?
Thanks
Old Jul 13, 2010 | 08:36 PM
RockmanX's Avatar
yes 1000cc will majority of people will tell you to upgrade to 1450cc for it but if all you want is 500 the 1000cc are perfectly fine
Tonba's Avatar
Nope... Personally I would be using a minimum of 1450cc for more headroom.
Old Jul 13, 2010 | 08:40 PM
Ted B's Avatar
The 1000s will do it, but not by much. 1250s are a better option. You haven't mentioned a dual fuel pump setup - you want one.
Old Jul 13, 2010 | 08:41 PM
Tonba's Avatar
^ +1
Old Jul 13, 2010 | 08:47 PM
nikg's Avatar
thanks guys, im gonna try it on the 1000's and see how high the idc's get. double pumper would be sick but i dont think i will need it until i build the block. This is the highest i will go on the stock block.
Old Jul 13, 2010 | 08:51 PM
Ted B's Avatar
Monitor your fuel rail pressure, and you will see it dropping before 500whp with a single pump. Whether you build the block or not makes no difference as far as adequate fueling for 500whp with E85 is concerned.
Old Jul 13, 2010 | 08:53 PM
JRivera's Avatar
2150's
Old Jul 13, 2010 | 08:56 PM
EmeryatSTM's Avatar
All depends on the dyno. We just finished a car that made 450 whp at 110% IDC with 1050cc's. You will probably run out of pump before those 1000's will make that power on our mustang dyno. We will be installing a double pumper and I will let you guys know what happens.
-Em
Old Jul 13, 2010 | 09:05 PM
FastLearner's Avatar
ID 2000s =D
Old Jul 13, 2010 | 09:15 PM
awdturbo8's Avatar
ID 2000 ftw ^^^^^
Old Jul 13, 2010 | 09:42 PM
ScorpionT's Avatar
If your injectors can handle a bump in fuel pressure, they should be fine for 500whp (as Emery said, it also depends on the dyno).
ID or something similar would be a good choice, because with a double pump you can run high fuel pressure safely. If you are planning for more than 500whp, the ID2000cc are not a bad choice.
Old Jul 14, 2010 | 01:30 AM
churchja's Avatar
Three that you should consider for a 500 hp E85 setup:
FIC Bluemax 1450cc
FIC Bluemax 2150cc High Impedance Injectors
ID2200 High Impedance Injectors
NOTE: The Bosch cores used in both the FIC 2150's and the ID 2200 are for all purposes the same. Although the wild paint of the ID 2200's sure do look cool.
Most setups I've seen stick to the base fuel pressure of 43.5 psi (stock). You're asking more from the pumps when you crank up the fuel pressure. Maybe considered safe, but IMO unwise unless your only option.
Both these High Impedance Injectors manufacturers advertise better cold starts and idle with E85.
lonniee23
Jan 9, 2017 04:15 PM
boost556
10
Jan 25, 2016 04:01 PM
kseriestuner
E85 / Ethanol
48
Oct 20, 2015 08:23 AM
razorlab
32
Nov 8, 2008 08:57 AM
