Quick clutch question
Old Jul 18, 2010 | 06:13 PM
Evo9tunerz's Avatar
So I got my new act clutch and installed it, but I forgot to clean the new flywheel and pressure plate before installing it. The new clutch and flywheel came with some anti corrosion oil on it. My question is should I take out the clutch again and clean it or will the grease eventually burn off?
Old Jul 18, 2010 | 06:21 PM
sho669's Avatar
I'd imagine it will chatter like hell...if a couple fingerprints can cause hotspots then thw whole thing being coated can't be good...
Old Jul 18, 2010 | 06:45 PM
Evo9tunerz's Avatar
The noise I could live with but the performance of the clutch is what I'm more worried about.
Old Jul 18, 2010 | 06:51 PM
sho669's Avatar
I deff think the life of the clutch could be shortened not running clean. I've never put one in that I didn't clean up first so I can't say for sure...I know I would have trouble sleeping knowing it could ruin a new investment though.
Old Jul 19, 2010 | 09:51 AM
Evo9tunerz's Avatar
Who agrees with using brake cleaner to clean off the oil on the flywheel and pressure plate?
Old Jul 19, 2010 | 09:54 AM
sho669's Avatar
Thats what I always use
Old Jul 19, 2010 | 01:17 PM
Evo9tunerz's Avatar
Thanks for your input sir, I really appreciate it. Do you think it's safe to say I can spray it on while the clutch is still bolted up? I'm probably going to slide the tranny out a little and clean it that way. Don't want to go through the hassle of bringing it up again. Good idea?
Old Jul 19, 2010 | 01:53 PM
sho669's Avatar
I would deff pull it back apart sorry...thats the only way you are going to get all the oil off of the contact points.
Old Jul 19, 2010 | 02:01 PM
dyezak's Avatar
My reading comprehension sux...but I caught it before I posted I agree with sho669.
Old Jul 19, 2010 | 02:15 PM
4RETECH's Avatar
Take it apart completely and clean it. The grease will eventually cause the flywheel to have hot sports where the grease burns into it, thus causing chatter later.
Duby
Feb 1, 2011 10:41 AM
ch53avitech
10
Dec 8, 2008 02:17 PM
ElectricBlueIX
57
Sep 14, 2008 09:37 PM
sykou
Lancer Tranny/Drivetrain Tech
Aug 12, 2008 09:45 PM
prototypemike
11
Mar 27, 2005 07:46 PM
