Engine ticking sound help...
Old Aug 31, 2010 | 09:54 AM
Street gear's Avatar
Originally Posted by dgrumpys
man.... get a long screwdriver and poke aroudn the engine to find location of that noise. top or bottom end. then go from there. good luck
It seems to be coming around the valve cover but so hard to tell.
Old Sep 2, 2010 | 06:51 PM
outtanowhere's Avatar
take valve cover off and check the rollers.and anything loose,
Old Sep 2, 2010 | 07:42 PM
Did that already did not find anything unusual. I even put in new lifters and it made no difference. The valve train looks fine.
Old Sep 3, 2010 | 06:11 PM
Not4Sale's Avatar
I was going to say hydraulic lifters but if you already checked the rollers and had the valve cover off then it must be something else.
Old Sep 10, 2010 | 10:26 PM
The verdict is 2 spun rod bearings on cylinder 3 and 4? The shop claimed my oil pump must of failed causing the bearing to wear. The crazy thing is did build only 1000 miles ago and the bearing are worn down to the rod. I will try to post pictures when I get them.
Who else on here has had an oil pump fail?
Old Sep 11, 2010 | 09:18 AM
red03evo's Avatar
sorry to hear about that.
who built the motor?
Hassan
103
Aug 5, 2023 11:37 AM
nissanfanatic
Jul 2, 2016 06:25 AM
Evolution 8 MR
Dec 1, 2012 11:53 AM
Sakamara
12
Mar 1, 2010 04:04 PM
blaze_125
Lancer Troubleshooting
22
May 4, 2009 09:45 PM
