Spun rod bearing getting prepared to build NEED ADVICE
Old Oct 19, 2010 | 07:29 PM
ilikeppie's Avatar
Hey everyone, I ended up spinning a rod bearing this last weekend and I figure there is no better reason to build than this. I have been wanting to build this motor for a while just never really had the money to tear down a perfectly good running motor. But now I kind of have to so I want to do it as good as possible for a decent price, I'm not talking cheap stuff just want best value for the dollar and not the most expensive parts I can find either. I would like some input on what people would recommend on this build. What I was thinking was either a 2.0LR or a 2.2L stroker with Manley Turbo Tough pistons, Manley or JE 10.0:1 pistons, and a Manley forged steel crankshaft. I will be getting the block O ringed the head ported with Supertech duel valve springs HKS 272's and a FP Red with other supporting mods. Thanks for all your input!!!
Old Oct 19, 2010 | 07:30 PM
Aby@MIL.SPEC's Avatar
what are your power curve goals, fuel used with turbo choice?
IMO, 2.4L
Old Oct 19, 2010 | 08:17 PM
ilikeppie's Avatar
I am kind of looking to build the motor to handle a bigger turbo down the road but still perform good with the FP Red right now, I will be using E 85.
Old Oct 19, 2010 | 08:29 PM
HeadGames's Avatar
how big is big...the block doesn't really need to be o'ringed till over 1000whp
You can't go wrong with any other of the engine choices your pondering..the manley bottom end pieces are top notch.
if it were mine, under 1000awhp, I would do Wiseco piston, Manley rod and crank, ported head with stock size Ferrea valves, the supertech spring kit works, you could also do Kiggley or a Ferrea Beehive.
Old Oct 19, 2010 | 09:05 PM
ilikeppie's Avatar
why Wiseco pistons under 1000hp? any reason? also i was thinking about sticking with stock valves is this a bad idea?
Old Oct 21, 2010 | 08:03 AM
Gadiel@Big Valley's Avatar
Hey Dave check your PM I send you a message.
Take care
Gadiel
Old Oct 21, 2010 | 08:32 AM
bougs's Avatar
I would only trust manley's crank.
Im not into china rods. Not to sure if the TT are though.
Please correct if I'm wrong.
Old Oct 21, 2010 | 11:08 AM
ilikeppie's Avatar
I have heard a lot of good luck with the stock crank as well, as for the rods i am pretty set on the Manley Turbo Tough
Old Oct 21, 2010 | 11:09 AM
RockmanX's Avatar
Nope Manley TT are straight legit boss I have them do wonders. Also the OEM crank is a beast dont know why it gets disrespected on the forums. I have seen plenty of stroker cars etc holding down massive power with the stock Crank. I would say 2.4 ALL DAY everday after learning all the stuff out i have about the 2.4 if your not a didicated dragger then for sure 2.4 can get them cheaper with alot of options. 2.0 or 2.1 if its all about dragging for your car
Old Oct 21, 2010 | 11:44 AM
ilikeppie's Avatar
I am more less going to use the car for street/drag racing
Old Oct 21, 2010 | 02:32 PM
RockmanX's Avatar
then do what you must
Old Oct 21, 2010 | 05:03 PM
ilikeppie's Avatar
right on man, I appreciate the input every bit helps me make a better decision
SBR INC
Nov 26, 2016 07:39 AM
danieljgermer
Sep 8, 2016 05:33 AM
iceman23007
Feb 3, 2013 06:00 PM
riceball777
Dec 27, 2012 05:48 PM
SBR INC
Evo 'For Sale' Engine Internals and Drivetrain
18
Aug 18, 2010 11:58 PM
