MAF Cleaning...CRC MAF Cleaner
Old Dec 6, 2010 | 07:43 PM
zeus1's Avatar
So i did some searches on using this product here and most are old but most have said they used with success at the time.
I noticed on the back of the can that the directions state not to use the product with mitsubishi's (see below). However they do not speficy which mitsubishi models so my question is does the evo (i have an 05) have a Karman-Vortex airflow sensor?
"10. DO NOT use on vehicles
with a Karman-Vortex air flow sensor, e.g. Toyota
Supra Turbos, Mitsubishi’s and most Lexus
vehicles."
http://www.crcindustries.com/faxdocs...on/st05110.pdf
Old Dec 7, 2010 | 09:05 AM
dastallion951's Avatar
well if ur gonna risk it....go ahead...personally you shuold be alright with the mass air flow sensor, main thing you gotta be careful about sprayin is this little red metal part in the flow sensor thats your heater to help the maf determine a/f ratio for the ecu...if you spray it get yourself and air compressor and air nozzle and spray out inside of the maf immediately after you spray it...good luck and remember its a couple hundred dollar part haha
Old Dec 7, 2010 | 09:09 AM
ROGERV's Avatar
I have used it multiple times on my 05 evo without any problems.
Alexl08's Avatar
ive used it on mine with no problems what so ever
Old Dec 7, 2010 | 10:42 AM
gsrboi80's Avatar
Been Using it for years now. Never an issue
Old Dec 7, 2010 | 12:43 PM
glgz's Avatar
I too have used a couple times with no issues. It worked great for me each time.
Old Dec 8, 2010 | 06:11 AM
Davo's Avatar
using an electrical cleaner with no issue
don't use the nozzle on the parts in the middle, use the open spray pattern when clenaing those pieces
also clean when maf is cold
Old Dec 8, 2010 | 06:54 AM
psphinx81's Avatar
i have used it multiple times as well before i went SD without any issues.
Old Dec 8, 2010 | 08:55 AM
05blue8's Avatar
Used it, on a few evo's, no issues.
Old Dec 8, 2010 | 09:18 AM
zeus1's Avatar
excellent thanks guys.
Old Dec 8, 2010 | 09:35 AM
Kracka's Avatar
Used many times with no issues.
Old Dec 8, 2010 | 10:35 AM
TommiM's Avatar
I used it a few times with no issues. I didnt use the straw because I didnt want to concentrate the pressure on any small piece that might break. A good idea as said above to clean it when its cold. The spray comes out pretty cool and if the maf is warm the temp difference might cause something to crack.
Old Dec 10, 2010 | 10:23 PM
mifesto's Avatar
just dont spray point-blank... besides that i've used it myself several times a-ok
Old Dec 10, 2010 | 11:40 PM
Danny23's Avatar
I swear by it,good stuff.
Old Dec 11, 2010 | 01:49 PM
goforwand's Avatar
I'll pig-pile on here...been using it for a while with no issues
