New BW EFR Turbo Thread
Old Sep 3, 2011 | 05:17 AM
  #751
leetEVO's Avatar
Originally Posted by chetrickerman
Personally I don't think a 2.2 with the 7670 would be a good fit. Reason I say that is because when I was playing around with BW turbo matchbot, the 7670 seemed to run out of steam past 7000 on a 2.0
I think the 8374 on a 2.2 would murder.
I have the twinscroll 7670 installed on a 2.3RPM motor and thusfar I couldn't be happier. For the cars purpose I think it will work out well.
Old Sep 3, 2011 | 07:44 AM
  #752
R/TErnie's Avatar
LEet, any dyno numbers? Data logs? Don't be holding out on us!
Old Sep 3, 2011 | 07:58 AM
  #753
leetEVO's Avatar
I just brought it down to socal to get it tuned. It will be tuned before the 17th.
Its now a matter of scheduling dyno time. I'll take paypal donations if you want to speed things up
Also, I dont' plan on running 40+ PSI... a lot less...
Old Sep 3, 2011 | 08:04 AM
  #754
R/TErnie's Avatar
Are you in Oregon? What are your goals power/ boost wise?
Old Sep 3, 2011 | 09:39 AM
  #755
chetrickerman's Avatar
Veteran: Army
Originally Posted by RSMike
derp?
Are you saying that if the client only wants 500whp and fast spool on a 2.2 litre engine you would still recommend a TS 8374?
how does that even make sense?
Lets all put massive 800hp turbo's on 2.0 litre engines running 300hp...
Based on the spool on the 2.0 with the 8374, 4k full boost is really good, and with a 10% increase in displacement it would be even better. Yes, I would still recommend the 8374 to my customer, as customers always want what?? MORE. Ask anyone on here, eventually they will want more. Why buy a whole new turbo when that time comes?
Obviously the 800 hp turbo on the 2.0 is NOT running 300 hp.
How is the top end? Does the power drop off at a certain rpm? Must spool like stock
  #756
leetEVO's Avatar
Its a fresh time attack track build... It will bounce between Utah and California. As far as power, I would like to be around 500ish with instant response / great spool.
I have a feeling "kill mode" for me is going to be around 32LBS... As far as the track goes, I want to see what 25-30LBSs on e85 does.
Old Sep 3, 2011 | 09:49 AM
  #757
leetEVO's Avatar
From my butt dyno, it was great lol.
What Im looking for is great low-mid range powerband and instant response.
As soon as I get it on the dyno I'll be happy to post the graphs. Like I said, from the limited testing (as its been on the car for two days) I'm in love with it.
Old Sep 3, 2011 | 12:08 PM
  #758
R/TErnie's Avatar
to me it's not only static power curve (I typically look how close to 4000rpms the engine makes 400 lb ft), but the inertia of the wheel due to increase in diameter. As we all know increasing the diameter of the wheels (bigger turbo) increases it's inertia and therefore reduces it's ability to snap back to life (transient response). If I can hit my power goals with a 7670, then I'll have significantly better transient response and spool when compared to the 8374.
who knows... maybe with the 2235cc engine, E85, twin scroll 8374, and a well tuned EBC @ sea level I'll be able to have a static spool closer to 4k than what the FFTEC Evo did on an open .83AR turbine housing. But I would probably only consider that if the 7670 couldn't muster over 600whp.
i think I'd be more disappointed coming out of a corner and not having throttle response to rotate the car, than not having 50 or more whp at the strip.
I'll just start dropping weight out of my Evo once I hit 600whp. And it will be on an eternal diet of Titanium, Carbon, and aluminum.
Old Sep 3, 2011 | 02:36 PM
  #759
n2oiroc's Avatar
What do you guys think of these for a 10:1 2.2L with a headgames race head and a 1.05 ts 8374? Too much?
Old Sep 3, 2011 | 06:06 PM
  #760
runuts's Avatar
They look very similar to the Keflord TX276HL's, which I can assure you, work very well in a 2.2 with Twin Scroll HTA86.
I'm currently trying to decide between the 8374 and 9180 with 1.05 for my 2.2. Not sure if my transmission will enjoy the torque of the 8374 down low. (Its an evo 3 btw, so not as strong as the late model evo tranny)
Old Sep 3, 2011 | 06:11 PM
  #761
n2oiroc's Avatar
thanks for the input! how is idle and driveability? i dont mind a raspy idle and i dont expect stock driveability, but i dont want it undriveable in stop and go traffic.
Old Sep 3, 2011 | 09:39 PM
  #762
runuts's Avatar
Idle is pretty wild, sounds nice, but drives perfectly
Old Sep 4, 2011 | 02:01 PM
  #763
project_skyline's Avatar
I'm convinced. Thanks so much Patrick for finally posting that up.
For anyone looking for a 8374 in TS there is one on ebay for $1900+
Old Sep 4, 2011 | 10:37 PM
  #764
acssa's Avatar
That ebay add is false.... they dont have stock.
Old Sep 5, 2011 | 01:08 AM
  #765
johnsm's Avatar
yeah thats a Treadstone Performance post on ebay, i dont know why they do that and why their website says in stock, maybe to get more orders in to get larger discounts.
