what cams fp black 2.4
Old Jan 22, 2011 | 08:24 AM
GT35MR's Avatar
I'm doing a 9:7:1 2.4 and I'm wondering what cams I should use. I was thinking Gsc s3 or possibly s2.
Old Jan 22, 2011 | 08:25 AM
achilles3000's Avatar
Gsc 2 cams! Going to s3's would be pointless due to only being able to spin the 2.4 at 8,500rpms max..
Old Jan 22, 2011 | 09:00 AM
S13 Curtis's Avatar
I think you could spin the LR2.4 higher then 8,500rpm, youmust be talking about the 2.3
Old Jan 22, 2011 | 09:22 AM
GT35MR's Avatar
My 2.4 is going to be a standard not long rod
Old Jan 22, 2011 | 09:27 AM
Murf's Avatar
Gsc s2, kelford 272, cosi no going wrong with any of those cams
Old Jan 22, 2011 | 11:49 AM
JohnBradley's Avatar
It will take some doing to make it idle correctly on an VIII but I would go with the S3 if you have any headwork done. The S2 will make good power on a stock head, like this-
https://www.evolutionm.net/forums/ev...omparison.html
aaron
Old Jan 22, 2011 | 12:50 PM
RockmanX's Avatar
I have fp 4r in my std 2.4 and its getting the job done and sounds great but cant go wrong with GSC s3 or s2 as John bradley has stated
Old Jan 22, 2011 | 02:23 PM
The trick to getting large cams to idle is playing with the intake cam timing, btw.
Old Jan 22, 2011 | 06:46 PM
GT35MR's Avatar
What's the cost difference between the cams listed? I am going to do stainless standard sized valves and not sure which springs because different cams require different springs. With a s3 I will have to go with a dual valvespring for sure right? What is the most cost effective springs?
Old Jan 22, 2011 | 06:53 PM
n2oiroc's Avatar
not exactly. you can use good single beehives like kiggly or gsc's.
Old Jan 22, 2011 | 07:25 PM
mayberry's Avatar
S3's. You're moving a ton more air than you would be with a two liter. I think the S3's will be just fine. MRTALON20 made almost 100whp with s3's over his Kelford 272's on his 2.4 6262 set up.
Old Jan 22, 2011 | 08:29 PM
GT35MR's Avatar
Anyone else think the s3's will work withthe fp black well?
Old Jan 23, 2011 | 07:11 AM
lillev23's Avatar
I'm definitely thinking about giving these a try for my fp black setup.
Old Jan 28, 2011 | 03:06 PM
BLKCarbonEVO's Avatar
I would go S3s. You have a 2.4 so spool will be fine. You want the extra flow capacity in the higher rpms
Mikey
jake33
14
Sep 16, 2015 06:28 PM
TunerHead24
Aug 31, 2015 08:44 AM
localtoys73
Oct 16, 2011 04:01 AM
EgyEvo
14
Jun 23, 2011 05:49 AM
sstrobl
13
Jan 14, 2011 05:54 AM
