Car won't go into gear.
Old Mar 19, 2011 | 10:26 AM
playmajohn's Avatar
I floored it in 2nd gear and tried to shift into 3rd at redline but it just would not go.
Pulled over, turned the car off then back on and it would not go into any gear and the pedal felt soggy and pulsating. Turned the car off again, put it in 2nd, and drove the car home. After I drove the car into my driveway it started to work like normal so I put it into 1st gear. Once I took it out of 1st gear in my driveway, problem started again and would not go into any gear.
I replaced the slave cylinder and bled it out. No luck.
My question is: Should I try to replace the Master cylinder first before I drop the whole transmission out of the car?
Has anyone had this happen to them? If so what is the problem?
Thanks,
John
Old Mar 19, 2011 | 10:34 AM
sharkm87's Avatar
ok so with the motor off...it goes in al the gears fine?
playmajohn's Avatar
yes
Old Mar 19, 2011 | 10:53 AM
sharkm87's Avatar
oh... than its master cylinder.. fork...clutch...
maybe if someone looked as u hit clutch see if its movin the fork or not..
when i had this issue it was my trans that blew from oil leak...but mine wouldn't go into gear with car off...luckily thats not ur issue
Old Mar 19, 2011 | 11:27 AM
dastallion951's Avatar
well u can try the slave cylinder, what you can also try is adjusting your clutch pedal underneath dash to see if it helps...also check your linkage under hood make sure its not kinked or anything
good luck
Old Mar 19, 2011 | 11:56 AM
playmajohn's Avatar
I would like to add that I have not lost any fluid and the pedal does feel weaker now
Old Mar 19, 2011 | 12:05 PM
try the adjustment on the pedal, search on here youll find a how to, or dont wanna jinx ya but possibly might need a new clutch search on here so u can get an idea of what ur lookin for
Old Mar 19, 2011 | 12:39 PM
playmajohn's Avatar
I want to add I have no been losing any fluid and the pedal did start to get softer.
Old Mar 19, 2011 | 02:31 PM
check for fluid leaks from the clutch lines, check the master and slave cylinders for leaks.... slave cylinder is on the trans has a bleeder valve on it. double check it, best bet, is to remove the dust cover under trans and try to inspect the clutch, dont be suprised if you find some stuff layin in it. good luck
Old Mar 19, 2011 | 07:32 PM
keevo54's Avatar
i have the same problem.......have no idea what it is..... mine makes a funny noise when the car is on and the clutch is pushed in. does urs do this?
playmajohn
22
Jun 13, 2017 11:47 AM
IggyBcool
Dec 6, 2014 02:42 PM
tlsole
Jan 6, 2011 02:54 PM
JRR
Lancer Tranny/Drivetrain Tech
11
Aug 28, 2010 08:01 AM
VRamirez2004
16
Oct 6, 2008 11:18 PM
