cylinder 1 not getting fuel
Old Apr 8, 2011 | 12:47 PM
Evofletch's Avatar
hey guys so my cars is not getting fuel in cylinder number one been looking around and seen that it could be the resister pack ive dont everything this can be my last option so if anyone know if thats what it could be or have any ideas how to help or what i could do please help me out guys thank you
Old Apr 8, 2011 | 01:03 PM
05blue8's Avatar
It could be alot of things...injector, wiring, ecu, resistor pack...what all have you checked?
Old Apr 8, 2011 | 01:04 PM
sho669's Avatar
Is there voltage at the injector?
Old Apr 8, 2011 | 09:00 PM
Evofletch's Avatar
The only thing I can think of is my resister pack because all my other injectors work it's just #1 that is not working so that's all I can think of
Old Apr 8, 2011 | 09:05 PM
GearedUp's Avatar
If one injector isn't working did you ever think it could be the injector? Ohm the injector and compare it to your other ones, if that checks out ok then grab a noid light and plug it in to the injector harness and make sure you are getting pulse. If you are getting pulse and the injector ohms correctly it could still be clogged. Let us know what you have tried.
Old Apr 9, 2011 | 12:28 AM
Evofletch's Avatar
Ok I've done everything I swapped injectors used injector cleaner still nothing and I also wanted to know if a dsm resister will work on an Evo 8 seen on here some where it will just wanna double ask
Old Apr 9, 2011 | 04:14 AM
Evofletch's Avatar
Anyone know
Old Apr 11, 2011 | 06:22 PM
CO_VR4's Avatar
Anyone know
Yes, it will. A number of us have used the DSM injector resistor box to modify for Bosch injectors (ID1000s and 2000s need the resistor box bypassed) in order to save the Evo one to put back to stock if needed.
The Evo manual shows that each injector has a separate resistor path, so it is theoretically possible for one of the resistors to fail; however it is very rare if it happens at all. When you swapped out the injector what did you do and what happened?
evoballer
14
Nov 15, 2019 09:42 AM
needsboost
25
Jun 28, 2015 02:02 AM
Evolved23
Sep 29, 2011 05:26 PM
sohcpunk
14
Jun 19, 2011 03:33 AM
weebles
12
Mar 16, 2010 04:28 PM
