No power to wheels when car is in gear.
Old May 10, 2011 | 06:06 PM
Maniac683's Avatar
Ok so not sure at all whats going on. I can put my car into any gear just fine without pressing the clutch pedal. While its in gear I have no power to the wheels. After inspecting the clutch and flywheel everything seems fine there. Any thoughts or help would be greatly apreciated.
Old May 10, 2011 | 06:54 PM
barneyb's Avatar
Clutch or center diff are two places that come to mind.
Old May 10, 2011 | 07:32 PM
Maniac683's Avatar
clutch has less then 2k miles on it shouldnt be the problem and seems to be moving and doing everything fine. If the center diff is the problem would I be able to put the car into gear (with it running) without pushing in the clutch? My guess is its something between the clutch and the transmission I just dont know what exactly goes on between the two peices.
Old May 10, 2011 | 07:43 PM
Tuxevo's Avatar
Check your ACD lines, pump and reservoir. If they're damaged the ACD defaults to open and you go nowhere.
Old May 10, 2011 | 09:46 PM
barneyb's Avatar
The clutch pressure plate is bolted to the flywheel and the flywheel is bolted to the crank. If the engine is running all of this is spinning.
The clutch disk is splined to the input shaft of the transmission. Release the clutch and the pressure plate clamps the disk. Now, the transmision input shaft is also spinning. There isn't anything else going on between the engine and transmission.
BTW, if the center differential defaulted to no movement there'd be a lot of cars disabled because hydraulic pump problems are common.
Old May 10, 2011 | 10:04 PM
Playap07's Avatar
Veteran: Air Force
Check your driveshaft. is your driveshaft good? (attached)
Old May 10, 2011 | 10:13 PM
Acree's Avatar
I guess I'm the only who caught this... but if you can put your car into gear, with the car running, without pushing the clutch pedal, then it's something related to the transmission.
Your clutch is always engaged unless the throwout bearing is moved. If you can move the shifter around freely, either you're entire transmission is fcked, or your shifter linkage is not connected.
-Acree
Old May 10, 2011 | 10:27 PM
Playap07's Avatar
Veteran: Air Force
yup i miss read that. Yea something is hella fishy!
Old May 10, 2011 | 10:38 PM
02-Lancer-Es's Avatar
Sounds like the clutch or broken shaft
Old May 10, 2011 | 11:04 PM
savagejay1's Avatar
I'm curious, when you turn your car on do you still have to disengage the clutch (press the clutch pedal in) in order for it to start, or are you able to turn your car on without pressing the clutch pedal?
Old May 11, 2011 | 08:18 AM
barneyb's Avatar
It might help if we had some 'how exactly did this happen' information.
Old May 11, 2011 | 08:50 AM
testa corse's Avatar
maybe you should go to a professional to check the problem
Old May 11, 2011 | 09:09 AM
StreetThisEvo's Avatar
Tcase diff is f'd up. It either is cracked or in a lot of pieces. Just my guess.
Old May 11, 2011 | 10:04 AM
Maniac683's Avatar
Problem started when was driving on the highway. Down shifted from 5th to 4th. When I let off the clutch I had no power to the wheels. I didn't feel anything different and didn't hear anything break. Had music on which could of drowned out anything breaking.
Old May 11, 2011 | 12:52 PM
Arctic Silver's Avatar
Just a thought, but what is your clutch slave cylinder was stuck in the out position. Basically when you push in your clutch the slave cylinder is the last component in the system that actually disengages the clutch disk. If you can go into and out of gear without pushing in the clutch and can't get the clutch to engage I would start by looking there.
evoul18
Nov 3, 2016 07:32 AM
Bananayellowevo
Apr 25, 2016 09:54 AM
ChefJMB
Jul 13, 2013 10:13 AM
undressesitself
Sep 9, 2012 08:48 PM
IntegxX
12
May 2, 2012 07:21 AM
