Exedy Twin Problems.. Clutch pedal vibrations!!!!
Old May 18, 2011 | 02:57 PM
18bora's Avatar
Exedy twin SD, installed new about 3-4k miles ago. The clutch pedal was adjusted and a Fork Stop was installed (1/4” space). Other that the normal twin noises and cold (very cold) weather first gear hard engagement, I haven’t had a problem….. Until my track day.
Half way into my 4th session, I started to feel clutch pedal vibration. The vibration starts as soon as I put slight pressure on the pedal and it goes away when the pedal is all the way down.
With the pedal all the way up, no vibration whatsoever. As soon as I apply slight pressure, vibration starts (a lot of vibration). The more I push the pedal down, the less it vibrated; and it went away when pushed all the way to the floor. While this was happening, I had no problems shifting into gear or driving.
Since I wasn’t sure what was going on, I packed and went home. 45 minutes into the drive home (stop and go traffic), after shifting, the pedal only came back up ˝ way. While shifting (only this time), it felt as the clutch didn’t completely disengage and I slightly grinded 2nd gear. I pulled the pedal back with my foot, thinking this is it, AAA time. To my surprise, the vibration went away completely and drove all the way home (another hour+) like nothing ever happened…. And still driving like nothing ever happened!!!! Some footage from the event http://www.vimeo.com/23883554
Anyone experience similar problems?!!
Old May 19, 2011 | 01:51 PM
18bora's Avatar
Anyone!
Old May 19, 2011 | 02:03 PM
binky's Avatar
I would try to re-bleed your clutch line. Make sure everything is tight (i.e. the lines are tightened down and that there are no leaks around the crush washers).
It could be the slave cylinder, or the master cylinder (which is much more rare) is shot.
Also, the transmission has a hole in it to release the throw-out bearing, take the rubber grommet out and look in it with a flashlight to make sure things are working properly. Have a friend push the clutch in and out and see what happens while you are looking through the hole.
-Bink
Old May 19, 2011 | 02:14 PM
Pirana's Avatar
Just went thru this. In my case it was the TOB vibrating in the bearing tube. (where it slides in)
Old Nov 7, 2011 | 04:56 AM
ifur's Avatar
how did you resolve the issue?
Old Nov 7, 2011 | 11:05 AM
Pirana's Avatar
My clip had come loose. I let it go to long. That damaged the TOB. I switched to a QM with hyd TOB.
Evo_Goodness
Jun 28, 2016 11:29 AM
vaflyboi757
Dec 18, 2015 10:27 AM
bluevilevo8
11
Sep 7, 2015 06:30 AM
Olms2468
May 14, 2015 05:48 AM
kouzman
Jun 29, 2007 07:19 AM
