kelford 272 good for my setup?
Old Aug 11, 2011 | 05:27 PM
ianVIII's Avatar
Originally Posted by Paliboost
Kelford's have always been more agressive then the other brands. Might wanna keep that in mind.
more aggressive then the mx1s or mx2s?
Old Aug 11, 2011 | 05:28 PM
Mikey@Spec-Ops's Avatar
You need to define agressive... if you mean more advertized duration that means jack. I'm not going to get in a pissing battle over cams, it has been done a lot already. There is a reason why 95% of shops run GSC cams and why GSC cams are on back order 95% of the time.
Mikey
Old Aug 11, 2011 | 05:40 PM
gpintoevo9's Avatar
or u can rewire the pump to make it like a flux capacitor and it will run like hell once u pass 60mph, trust me bro.. i did it.. better than cams....
Old Aug 11, 2011 | 05:49 PM
Paliboost's Avatar
Kelfords
Duration @ 0.1mm Valve Lift: 272 Inlet/272 Exhaust
Duration @ 1.0mm Valve Lift: 226 Inlet/226 Exhaust
Valve Lift @ 1.73 Rocker Ratio: 11.00mm Inlet/11.00mm Exhaust
Centerline @ Full Lift: 107 Inlet/113 Exhaust
Old Aug 11, 2011 | 06:08 PM
evoiao's Avatar
kellfords
I had bought GSC s'2 and waited for over 7 months, with excuse after excuse on why there was a delay....I got tired of waiting and switched to the kelfords and have never, not once regretted the decision....my car has a lot more umph.......and it runs great and Im happy its a DD.....Kelfords.....plus I think kelford help with the gsc grinds? so I heard?
Old Aug 11, 2011 | 06:19 PM
Paliboost's Avatar
Mikey
I never said they where bad. To the OP 264/272 should proablly do the best. for a stock turbo.
Old Aug 12, 2011 | 09:45 PM
Derock2gspyder's Avatar
Running gsc s2s on my 9 with stock turbo! Put down good power and great idle still! Gscs are great cams! Kelfords are good as well but seen better results with gsc!
Old Aug 26, 2011 | 05:19 PM
524hpSRT-4's Avatar
Mikey
true story
Old Aug 26, 2011 | 06:20 PM
wcportell's Avatar
I would recommend the Forced Performance FP4R's they are designed to be used with the stock valvetrain.
Old Jun 25, 2014 | 08:18 PM
EvoRoc's Avatar
Gs2
Correct! They spool the exact same as a S1 but make about 15-20whp more. I can get a good deal on some S2s for you. Shoot me a text or pm if you are interested.
Mikey
Mike you still have anymore deal on the gsc2? If you do let me know thank.
iitzbebo
Apr 26, 2021 02:42 PM
SrBlacksheep
13
Dec 1, 2013 09:09 PM
RickU
14
Sep 20, 2013 11:50 AM
waylonmunoz2005
20
Jul 9, 2011 10:04 AM
EvoStevo777
May 3, 2011 03:45 AM
