Walbro 400LPH intank pump ? Anyone got any info
Old Oct 4, 2011 | 08:43 PM
  #166
wizzo 8's Avatar
I knew it could be done. I have a dw300 pump with the stock fpr. No problems with over running. I'm sure this would overrun it though. Just curious how this pump will do with E85. I haven't seen anything saying its compatible. Does the walbro come with the electrical connector pictured? Good write up by the way
Old Oct 4, 2011 | 08:55 PM
  #167
turbotalawd's Avatar
In for more pics. I hope ryu is seeing this thread.
This one is supposed to be quieter than the 255.
Old Oct 4, 2011 | 09:24 PM
  #168
dcamp56's Avatar
Looking to make 700 whp we have an HTA35r on the car
Originally Posted by sourcelx
As with any 300lph setup Im assuming this would need a fpr aswell? Im also curious on how loud it is.
its not really that loud! and we dont have a FPR on the car yet thats next lol
Originally Posted by 1UpMoto
Nice, I was thinking about trying the same thing just because buschur said it wouldn't work lol. I still havn't seen one in person do you have a comparison pic to a normal walbro 255? How much did you have to trim off of the housing? Thanks
-Nick
If you notice on the housing where the bottom piece clips in to secure the fuel pump, there are 3 locations for the clips to grab onto. You are going to want to grind the plastic to almost the beginning point of the clip (look at image 3). Once that is completed you will notice that the walbro increases in diameter towards the bottom of the pump. You will need to shave the inside of the housing so just about 2 cm of the walbro fit. One this is complete test it out by sliding the walbro into place and snaping the bottom clip into place.
The walbro 255 clip plugs right into the new 400 pump wiring, NO CUTTING!!!
Old Oct 4, 2011 | 09:27 PM
  #169
SyZyGy1394's Avatar
MOAR detailed pics plz!
  #170
dcamp56's Avatar
the setup kit is sold separately its 25 dollars.
We sell the pump with setup kit for 180.00 shipped
Also we run e85 in our evo i will be posting numbers what we finish tuning the car
Old Oct 4, 2011 | 09:28 PM
  #171
dcamp56's Avatar
i wish we took more! lol the pumps in the car maybe will get another customer who wants one if anyone on LI and wants it will do it for cheap! just so we can shoot some new photos.
Old Oct 4, 2011 | 09:33 PM
  #172
wizzo 8's Avatar
You using factory wiring still?
Old Oct 4, 2011 | 09:36 PM
  #173
dcamp56's Avatar
nah walbro 255 clip plugs right into new harness
i believe factory wiring will work
Old Oct 4, 2011 | 10:09 PM
  #174
Babi@Force-Fed's Avatar
good on ya...... now is time to test. GL
Old Oct 4, 2011 | 11:32 PM
  #175
1UpMoto's Avatar
nice, sounds like a pretty quick job.
Old Oct 4, 2011 | 11:49 PM
  #176
RyuEvoIX's Avatar
MRP FTW! Will only fit in a double pumper my a$$.
But buschur said it wouldn't fit! This is IMPOSSIBLE! ALL LIES!
Ofcourse it "wouldn't fit" as it's no where near as lucrative as a double pumper sale.
Originally Posted by awdordie
David will be in here soon to retract all previous statements. It would be evven sweeter if it had been the guy in that thread arguing with david that figured this out to rub it in his face.
But good job figuring this out none the less. You have one uped david buschur whether you knew it or not cuzz like stated before he said "it simply can't be done" end quote.
No he won't. He's too cocky and full of himself to admit fault. Yes it would have been sweet had I gotten a hold of a pump and posted details first since I was the one that directly defied David Buschurs claims that this pump won't work for the 8/9, but a big hats off to these guys for doing what I completely believed could be done. Making this pump fit at VERY LITTLE EXTRA COST! As I planned before even seeing this thread, I will be ordering one of these pumps at the end of the week. I'm happy to say, with this pump, I will never need a double pumper for my setup.
Thanks to another member sending me the link to this thread in a pm, I was made aware of this thread.
Old Oct 5, 2011 | 12:24 AM
  #177
TurboTravis's Avatar
For everyone asking about doing an upgraded fuel line, Aeroquip Pushloc (available from Jegs, Summit, etc) is ethanol compatible and very easy to work with. If you're in need of upgrading the stock fuel line, this is without a doubt the easiest way to do it. In my case, with the Buschur Double Pumper, -6 (3/8") Pushloc simply slides over the outlet of the filter supplied with the double pumper, and you can use this to connect it to the rail-
http://www.streettunedmotorsports.co...l_fittings.htm
Zero reason for 99.9 percent of the cars on here to go bigger than -6. FWIW, my car saw a massive DECREASE in injector duty cycle from upgrading the line. Cheap, easy, and no reason why it should not be done on a car that's making over ~500whp on ethanol.
EDIT- Aeroquip hose from Jegs http://www.jegs.com/i/Aeroquip/023/F...rentProductId=
Old Oct 5, 2011 | 12:57 AM
  #178
tsidrift1's Avatar
This is great news!! In for results!
So, a FPR is def needed for this pump then?
Old Oct 5, 2011 | 02:44 AM
  #179
evilempire76's Avatar
I'm glad someone figured this out. I figured it would be a matter of time.
I would like to know this as well.
A single pump would at least give linear flow. When my double pumper kicks in the AFR goes rich at part throttle. I would think a single pump would keep this from happening.
Old Oct 5, 2011 | 03:16 AM
  #180
justincase's Avatar
after reading this thread my head hurts sooo much i think i will look into a surge tank and external pump - much more suited for my applications and much less head noise and name calling...
