Few issues with my evo
1) It makes a kind of a thumping noise which is loudest around 45mph. Passenger axle was leaking grease so I replaced it and it is still making the noise. Any suggestions?
2) Redline shifting issues which I believe is because of RPM hang. recently replaced my clutch and it just started. I'm thinking its my VSS on the tranny. Any suggestions?
Does the thumping happen in any gear at 45mph? When you say loudest at 45, does that mean it gets quieter above/below 45? Perhaps the road noise just drowns it out above 45?
If you can, I would suggest taking audio of the sound if you can and posting it. You might get more responses then.
Greetings to all im a new lancer driver..can someone please help me? I had my break pads and wheel bearings changed..but now on my display it shows ABS service in red while im driving? I checked the abs sensors is perfect.. what can the problem be? gillroxmarshall@iway.na Thanks in advance
jos76
Outlander Sport
38
Jun 18, 2017 06:04 AM
