Short Runner T4 TS GTX3076R Experiment
Old May 29, 2012 | 01:02 PM
  #196
240Z TwinTurbo's Avatar
Just for giggles, the cold run from March(blue) vs. the new run with the Curt Brown Extreme port(red).
Old May 29, 2012 | 05:30 PM
  #197
MrLith's Avatar
Wow, impressive!
Old May 29, 2012 | 07:39 PM
  #198
03whitegsr's Avatar
Would you post up one with the correction turned on and the correct weather data entered? Just curious how well they line up.
Old May 29, 2012 | 07:57 PM
  #199
So click the SAE box and enter the temperature? What runs?
Old May 30, 2012 | 04:24 AM
  #200
spdracerut's Avatar
Using the correction factor for SAE listed here:
http://www.motoiq.com/magazine_artic...lieve-one.aspx
For the winter run, it's about 0.956 and 1.004 for the latest run.
So that changes the peak numbers from 545>520 and 477>479. But two variables are not taken into account: 1. the extra 2psi of boost in the winter run and 2. the extra timing allowed by the colder weather. 42 deg F is a huge temperature difference which allows more timing to be run.
So this requires some more information, that being the timing run. 1 degree of timing is worth roughly 5whp on a close to stock engine. So I don't know how that translates into this engine which is much more highly modified.
Old Jun 16, 2012 | 09:48 AM
  #201
UPDATE:
Due to travel, progress has been slow. I was able to complete my battery relocation project so that I could make room for a larger intake filter. It was a fair amount of work, but I am happy with the results. Need to run the positive line to my stereo amp, but at least the car is running.
Old Jun 17, 2012 | 10:37 AM
  #202
UPDATE:
I had more time to install parts this weekend. Because the Haltech Platinum Pro PNP doesn't really control fuel pressure PNP as advertised I had to install an aftermarket FPR. I wanted to have it bolt right to the rail so I didn't have to find a spot in the engine bay.
I purchased the small universal Aeromotive unit and with a few fittings it bolts right up in place of the factory FPR, but has adjustability.
Old Jun 29, 2012 | 03:32 PM
  #203
UPDATE:
I am trying to finalize all the mods to so I can swap to speed density with the Haltech PNP. In order to run the new K&N filter, which is a 10" unit with 6" opening and velocity stack, I had to reroute the intercooler piping. I wanted to run it next to the clutch slave cylinder, but the stock hardline was in the way. I ordered a banjo fitting and new line and this has cleared room for the ic pipe.
I next installed the huge filter, which fit with minimal issues.
I will have additional pictures on Sunday as I am also going to run a Tial 44mm WG as a dual port BOV so I can eliminate the surge issues.
Old Jun 29, 2012 | 05:19 PM
  #204
Craig King's Avatar
Originally Posted by 240Z TwinTurbo
Something about this doesn't look right...
Old Jun 29, 2012 | 05:29 PM
  #205
Grover gives up
Old Jun 29, 2012 | 06:27 PM
  #206
h22gordo's Avatar
Great thread....thanks for taking the time to post. Some good reading.
PM sent.
Old Jun 30, 2012 | 09:12 AM
  #207
Craig King's Avatar
Grover gives up
I don't see any beers during the install!
Old Jun 30, 2012 | 10:53 AM
  #208
211Ratsbud's Avatar
Curious to see how you set the WG up as a BOV. I understand how it would work, but pictures and details, are always welcome to the imagination.
Old Jun 30, 2012 | 06:38 PM
  #209
I will make sure the wastegate eliminates the surge issues and then source a solenoid hooked to a Hobbs switch to cut on/off the bottom port.
Old Jun 30, 2012 | 06:58 PM
  #210
unijabnx2000's Avatar
Can you run through how you expect that to work for your issue?
