Kinugawa 25g turbo thread
Old Jun 12, 2017 | 08:38 AM
  #826
fishie36's Avatar
Originally Posted by evohq
Just bumped in to this thread. Very confused between FP Green and Kinugawa td06sl2r-25g :/
I have an Evo V btw. I am on a budget too :P . This looks like a great deal to me:
http://www.ebay.com/itm/Kinugawa-Bil...9Sp6Ko&vxp=mtr
So hows your Kinugawa holding up as of today?
I am running the td06sl2r-20g and it's still holding up well after ~4 years. I am currently making 475WHP at 28psi on E85.
Old Jun 12, 2017 | 05:05 PM
  #827
evohq's Avatar
Great! .
1. How would you compare 20g with 25g on a bone stock 4g63?
2. Can you share some details about rpms when it starts to build boost and around what do you hit the full boost? How it it holding up till the redline?
Thanks!
Old Jun 13, 2017 | 08:46 AM
  #828
fishie36's Avatar
Great! .
Thanks!
I actually had the 25G and it was way too laggy for me. Did nearly nothing until 5500+ RPM. Now with the 20G and the 1.5bar spring, it starts boosting around 3500, reaching full boost by 4200. Boost does hold until redline and HP keeps on climbing. I'll attach my vdyno generated by tscomptuned.
This is a stock motor with 100k+ miles and low compression in 2 cylinders. The only internals are GSC S1 cams.
Attached Thumbnails Kinugawa 25g turbo thread-6a1656e48418cc1fd1117650c089b073b47750a064a2a9ee24-pimgpsh_fullsize_distr.jpg
Old Jun 13, 2017 | 02:26 PM
  #829
evohq's Avatar
Thanks . Thats quite impressive chart!
Old Apr 16, 2018 | 07:39 AM
  #830
poonpower's Avatar
Bump!
25G with the TD06HR hot side, so its already bigger than the TD06SL, how would this do in terms of spool and top end? I plan on revving the motor till 8000rpm having the whole head built, but if the 20G can net me 400WHP on 93oct with good top end pull then I'll settle for the 20G instead.
Advice!!
Old Dec 17, 2018 | 06:10 PM
  #831
wisewendell's Avatar
What's your mod list? I'm on a 11 blade Tdo6sl2r with a billet extended tip 20g/antisurge housing
Looking at getting it retuned and curious on what kind of power it'll make
Old Dec 17, 2018 | 08:48 PM
  #832
kaj's Avatar
kaj
Judging by the post above, an FP HTA71 makes the same as the Kinylugawa, or whatever and is far cheaper than a Green.
a Green is good for 500+
Old Dec 4, 2022 | 11:51 PM
  #833
I<3myevo6's Avatar
Hi
GUYS PLS HELP ME OUT!!!!
Based on positive reviews I had bought a TDO6SL2R 25G from Kinugawa with a 5+5 blade compressor. The car is a evo 8 stock block and head. I got my car tuned with a 1000CC FIC injectors. Whatever I do I am unable to hit full boost until 5.5K RPM @26PSI(does not peak any further) the car already has a 2bar WG spring with full preload and no boost leaks.
I need your help to confirm if the 25G turbo lag is that bad and when does other members hit full boost in the RPM range with this turbo.
My ambient temperature is at ~35C
n2oiroc
12
Jul 13, 2018 11:29 PM
Yugi19911
Jul 29, 2017 11:38 PM
teamturbo
Aug 31, 2009 10:43 AM
Mj23foreva
May 18, 2009 03:12 PM
DJ Brett B
17
May 17, 2006 06:49 AM
