Kinugawa 25g turbo thread
Old Jan 25, 2016 | 08:55 PM
  #811
evo8vz's Avatar
Originally Posted by slippi84
Not sure what you consider laggy but this thing with the upgraded spring is much more responsive and buids full boost sooner. I haven't even tried to turn the wick up but with my boost controller turned down 30psi is easy. I have seen as high as 33psi
A red which has a 76mm wheel and I think Kanigawa is a 78mm wheel will have 600-800 RPM better spool.
I think the TD06 housing they use is way too big if I want a cheap turbo rather would go turbolabs.
Old Jan 26, 2016 | 07:21 AM
  #812
Llew's Avatar
What spark plugs would you guys recommend at 28-30psi pump gas? my tune is ultra rich,with no zero knock. Ive used ngk bkr8'son race days both they don't last, use mostly ngk bkr7's but have to change or clean them every 2-3months. Ive decided to try some 6's for daily driving on low boost but they seem to foul easily too.
race day is in march hoping to run a pump gas 1:1 mix with c16 and see what ET's I can get with 30psi
Old Jan 27, 2016 | 11:56 AM
  #813
eTiLiKo's Avatar
Originally Posted by eTiLiKo
The preload is already at the max, 4 full turns.
The actuator is fine, it begins to open at 19psi and holds the pressure, I cannot see any problem here.
Originally Posted by 94AWDcoupe
you have a flapper problem if you only get 23psi with no line on wastgate. you should get 40+psi by 5000rpm
Yes, this is the same idea I have. In a few days I'll remove and disassemble the turbo
Well, I have removed and inspected the turbo. The flapper is good. Not perfectly centered, but it seals the hole. The flapper surface and the mating face are perfect.
The actuator as I previously said is perfect.
What is REALLY horrible is the exhaust housing. The divider between the two volutes.........see the photos. It completely disappears at a certain point, and even when it is present it is too short in height.
The housing also seems to be really big, too big.
You get what you pay for...a useless turbo.
Attached Thumbnails Kinugawa 25g turbo thread-kinugawa-dsc_2721.jpg   Kinugawa 25g turbo thread-kinugawa-dsc_2723-copia.jpg
Old Jan 27, 2016 | 12:42 PM
  #814
94AWDcoupe's Avatar
no wonder these are laggy
Old Jan 28, 2016 | 06:59 AM
  #815
Evo8cy's Avatar
I assume this is the turbo everyone has bought and refer to on this thread :
http://shopping.kinugawaturbo.com/ki...0ps-4-3-1.aspx
If you choose to buy the above, if you have not one with a billet wheel already installed, buy the billet version of the wheel and install it. You will also need at least a 1,5 bar actuator. I am sure with a proper one used and the billet wheel mated to the td6sl2 wheel it will have a very good boost threshold, spool time and full boost rpm point.
Someone posted previously that the td06 housings are big. For those that do not know this, the td06 chra is used on the evo 9 oem turbos, 70,71,80 series ones.
Also another member said that the 10.5cm2 twin scroll housing he got with the 25g is bigger than the normal unit? So in other words it is not a 10,5cm2? Did you by any chance got the 11,5cm2 housing instead?
These turbos and a variety of others are also produced and sold by MAMBA, check them out.
Marios
Old Jan 28, 2016 | 07:03 AM
  #816
LetsGetThisDone's Avatar
I thought the Kinugawa housing was an 11.5? So, yes, its bigger. The short volute is likely due not wanting to spend the money for a proper mold, or they didn't want to use a good enough material for the volute to survive.
Old Jan 28, 2016 | 07:18 AM
  #817
Evo8cy's Avatar
On the link I posted the hotside is advertised as a 10,5cm2 one.
As for the casting process, the mold is the same for all. In the casting process as with any company doing cast parts, no matter the origin of the company, there is an imperfection factor involved, it is an un-doubtedly, given fact of the process. Fp for instance when they produced their cast exhaust evo 4-9 manifold had some of the units that came out with imperfections. Those units where the flaws did not affect performance were sold at a discounted price, and some were thrown away.The difference between a company that sells quality and another that skips a bit on it, is the fact that the non properly molded cast items are ditched, where another one might choose to sell.
Marios
Old Mar 8, 2017 | 12:19 PM
  #818
Llew's Avatar
guys where can i find a rebuild kit for the 25G ...my intercooler pipes are filled with oil
Old Mar 8, 2017 | 02:21 PM
  #819
andrewzaragoza's Avatar
you could try this.
http://shopping.kinugawaturbo.com/mitsubishi-4.aspx
Old Mar 9, 2017 | 11:15 AM
  #820
ineedboostman's Avatar
Mine ate the hotside bearing and starting rubbing the compressor housing after 1000 miles. Rebuilt it with MHI parts and put a new tdo6sl wheel/shaft in it. Still rubs the compressor cover. I think the cast of the CHRA are machined wrong or something. When I put the new bearings in the housing they can wiggle a bit. Im assuming thats why mine failed. Anyone want want a Billet turbo on the cheap?
Old Mar 9, 2017 | 11:21 PM
  #821
ziegler1224's Avatar
not bad
Old Mar 9, 2017 | 11:36 PM
  #822
FullBlown8's Avatar
not bad
Originally Posted by JSPturbo
Hello. A few weeks install this turbo for my Evo 5. I have a problem of pressure but will be adjusted for 30psi peak and 26psi to redline. Now boost is 21psi all the time.
The engine is:
2.0L Forged, Evo 8 MR Cams,Intake 80mm, Exhaust 3" and E85 pump.
I hope you like !!
first graph:
Escribe texto o la dirección de un sitio web, o bien, traduce un documento.
Cancelar
traducción del español al inglés
Old Mar 10, 2017 | 09:51 AM
  #823
Llew's Avatar
Originally Posted by andrewzaragoza
Ive been to this page but none specifies 25Gtd06sl2...so its confusing...
i bought a rebuild kit for my stock turbo and some of the parts did not work even though it said evo 16G td05hr so i dont want to end up getting something that wont work and have to ship it so far .
Old Jun 11, 2017 | 06:40 PM
  #824
evohq's Avatar
Just bumped in to this thread. Very confused between FP Green and Kinugawa td06sl2r-25g :/
I have an Evo V btw. I am on a budget too :P . This looks like a great deal to me:
http://www.ebay.com/itm/Kinugawa-Bil...9Sp6Ko&vxp=mtr
So hows your Kinugawa holding up as of today?
Old Jun 11, 2017 | 08:45 PM
  #825
ExViTermini's Avatar
I can count multiple poor reviews on just this last page......
