Kinugawa 25g turbo thread
reds and blacks make 300tq at ~3900
this snail hitting 300tq at ~5200
Last edited by WestSideBilly; Sep 7, 2013 at 02:57 PM. Reason: Removed vendor link
I'm pretty sure there is a large difference with exhaust turbine housings between the two. You can change the exhaust turbine on the 25g and I'm sure it will peak torque much earlier.
And I can take that ex tra savings and do a lot of things with it
Take my wife out to dinner ten times
Buy my kids something......
Thoses are great numbers....
How about wow good numbers
It pays to know the full story before making statements dude, i already stated this is my old turbo which had an external wastegate on the dump and the twin scroll effect had been eliminated therefore we got slower spool which equals less torque, i've already tuned several of these and both torque and power are on par if not better than other FP equipped Evos i've done, and for $1,000 as compared to $3,000 for an FP i can deal with the lower torque if that was the case.
it pays to know the full story before making statements dude, i already stated this is my old turbo which had an external wastegate on the dump and the twin scroll effect had been eliminated therefore we got slower spool which equals less torque, i've already tuned several of these and both torque and power are on par if not better than other fp equipped evos i've done, and for $1,000 as compared to $3,000 for an fp i can deal with the lower torque if that was the case.
Installing and external gate on an internally gated TS housing is about as dumb as it gets. but even that has been shown to slow spool by only 700rpm. This turbo is no where near as enjoyable as an FP turbo. you are miss leading readers to post that crap. I have seen about five graphs on these 25g setups. They all spool horrible slow. There arent worth the coin if you ask me. But if savings is such a big concern for ya then have at it. I could care less that you car is not as fun as it could be.
Why are we comparing turbos? Should I bring up an EFR and state that FP is not as enjoyable as an EFR... Cmon man. What is horrible slow spool for a turbo that's the size of a gt35r. I hit full boost at around 4.4krpm and power will not stop climbing. If you can care less, then why troll and post.
I take the time to post because there are those who appreciate my input on making proper selections.
Nobody misleading anybody here as you are obviously misinformed to think sohttps://www.evolutionm.net/forums/ev...-fp-black.html
Definitely the whole thing, the TD06 wheel will allow you to make more power on the top end, while doing the compressor upgrade it's a good improvement over stock it will still be limited by the factory TD05 wheel.
I compare the turbo to FPs because it has been brought up by guys using the 25g that it is a good alternative at 1000+ less. I say it is a sore alternative and wouldn't dare stoop to using one. The compressor wheel is 35r size. 35r and FP black are making 700whp. So why the rave about this 35r size turbo making 550whp with worse spool than a 35r?? problem is this turbo has a turbine wheel the size of old school greens, BBk and the like 450-475hp turbos. this is part of the reason no one can get this turbo to work well with the internal gate. theres too much back pressure blowing the gate open early and ruining twin scroll spool.
The FP Black is bigger than both 25g and 35r, it shouldn't be compared. I believe the Green is the better choice for this hp level. I haven't seen any 35r hit 700whp, can you show me? I've seen mostly 5-600whp with both 25g and 35r.With buying a turbo saving over a grand, I'd put an extra 150 and get the billet wheel. I totally agree with the internal wastegate problem. I'm having that too on mine. I'm not even using a 25g with a twin scroll turbine like you guys are. Mine is a regular t3 turbine for my SS.
turbo = size= lbs/min = whp typical on e85
35r =61.4mm= 68lbs = 650whp
hta3582=59mm=72lbs = 700whp
black =hta3582= 59mm=72lbs = 670whp (held back due to turbine housing)
25G= 60.5mm= 60-67lbs * = 550?? (so far wooho!) *original or billet
does that help?
This 25g to me is simply a mismatched combo of wheels. The compressor wheel is capable of 650 whp but its being held waaay back mounted to 6SL2 turbine wheel. not only is it held back in power but spool suffers as well. the 25g turbo would be waaay better if it was mated to 6H size turbine wheel. It is an inexpensive turbo that can make over 500whp. If working within extreme budget constraints then it may a be a good choice for people.
